Author Topic: Pagoda 230 SL fuel problems  (Read 484 times)
jose230sl
  • USA, FL, Miami
« on: November 15, 2024, 17:36:41 »
Hello, I have a 230 SL 1965, the car starts ok and run but after a couple of miles the car loose power and stops, it starts again. then I have the same problem 2 or 3 times again, looks like the fuel pressure is gone for some minutes. I need some help. the fuel pump has been rebuilt, the injection pump is working fine, so I don´t know what to do.
Re: Pagoda 230 SL fuel problems
« Reply #1 on: November 15, 2024, 17:39:12 »
Hello, and welcome to the group. I am sure someone will reply in a very helpful way
jose230sl
  • USA, FL, Miami
« Reply #2 on: November 15, 2024, 18:17:10 »
Thank you
dirkbalter
  • USA, CA, Corona
« Reply #3 on: November 15, 2024, 18:32:25 »
I would measure the amount of fuel returned to the tank to insure your fuel path is sound. (At the end off return line prior to going back into the tank).
If you read through the related section in our tech manual, you will have a good idea on what you want to see with respect to l/sec or so.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #4 on: November 15, 2024, 19:23:33 »
I am proud to admit I thought what dirkbalter wrote (he is an expert, I am an amateur).
This simple test shows overall flow efficiency of the fuel system, including return line (yes, if return line is clogged, you will have fuel starvation of the engine). Measure the flow of fuel at the end of the return line (at the tank). Put the end of return line into a canister  - something you can see and measure fuel volume. Switch on the fuel pump for a couple of minutes to worm it up, then measure the flow. You should get, say 0.8 liter in 15 seconds, better if more. If it is 0.6 liter or less - there is a serious blockage in the fuel lines.
If you diagnose the block, go step by step: first filter is the screen in the fuel tank outlet, then there is a screen in the inlet of the fuel pump (if you do not have in-line filter before the fuel pump), then there is the main fuel filter, then there is return line that may be clogged (be careful if you decide to blow it through with the air, put some cloth around the opening).
Do not blow air to the tank. Be careful and take precaustions when working with gas.
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #5 on: November 15, 2024, 19:25:11 »
The symptoms sound very typical of a clogged flower pot in the fuel tank -  rust settles in there and blocks the fuel flow.  Lots of info on the site.
May be time to have the fuel tank cleaned.  You may need to remove the tank to determine if it is rusted out -  they can rust from the top down and chunks of rust will fall into the fuel and clog the flower pot.
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
jose230sl
  • USA, FL, Miami
« Reply #6 on: November 15, 2024, 19:54:39 »
Thank you very much folks, I will do that this weekend and let you know, so far, I clean the tank and the lines, but I didn´t check the amount of fuel in 15 seconds. Grate
Thank you very very much
dirkbalter
  • USA, CA, Corona
« Reply #7 on: November 15, 2024, 20:19:10 »
Pawel, danke fuer die Blumen  ;). But I am no expert. Its all about learning by doing and it is amazing how much you learn over time.
On the above subject, I had a fuel cut off problem on my 280. It would randomly shut down and stop..... sometimes it would start again or not.
It turned out to be the connection of the fuse in the fuse holder. After cleaning the fuse holder contact, everything is good again. (You should be able to hear the pump running all the time)
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #8 on: November 15, 2024, 20:32:44 »
Well, to me you are.
It is about eliminating things. The fuel flow is one of the simplest tests. I had a very similar issue and it did turn out to be clogged filter after car restoration and a new tank - even then you get trash in the tank.
Bonnyboy
« Reply #9 on: November 15, 2024, 22:01:41 »
Checking the volume of fuel heading back into the tank will tell you lots.  I had a rusted tank and then found a pinched return fuel line under the car and then determined that there was not enough volume coming back into my tank.  A new fuel pump fixed that.
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
jose230sl
  • USA, FL, Miami
« Reply #10 on: November 20, 2024, 15:04:17 »
Hello, thank you very much, I did what you suggested and checking with 15 seconds at the return fuel line I have less than 0.8 lt, so we checked the fuel line and we found a problem there, we are going to fix the problem today and let you know.
« Reply #11 on: November 20, 2024, 22:13:44 »
You may want to consider fitting an in- line filter between tank and fuel pump. Fuel pump should have a screen in the fitting, but still…
Just be careful - if you have original fuel lines they are 9mm ID. Most filters are 8mm. So either do it the Kent’s way - fit short lengths of hose on filter fittings to increase their diameter, or find filter with 9mm fittings.
« Reply #12 on: Today at 01:00:33 »
What you do is work with facts, not assumptions. You got good advice and hopefully you found the problem.  If the flow rate is still low, let us know.  You can also search the forums or look in the Tech Manual for measuring frel pressure.
