Author Topic: Quiet, motor like sound emitting from under the antenna  (Read 178 times)
adkocen
  • USA, LA, Baton Rouge
« on: November 16, 2024, 18:02:00 »
So all of a sudden, I am hearing a sound from around the antenna or maybe under the fuel tank that sounds like a small motor. It starts when i turn the key but seems to not be part of hte antenna up and down. That happens only when the radio is turned on, and then it is a different sound. Any ideas?
Ari Kocen
1964 230sl Euro
Re: Quiet, motor like sound emitting from under the antenna
« Reply #1 on: November 16, 2024, 18:10:34 »
Fuel pump?
adkocen
« Reply #2 on: November 16, 2024, 19:00:07 »
Could be, what sound would it be making, though when the engines not on but the battery is?
Thanks for the response.
« Reply #3 on: November 16, 2024, 19:21:35 »
Turn on the ignition but don't start the engine, then crwal underneath the rear of the car, driver's side and you can see if it is indeed the fuel pump. If it started suddenly, it may be on its way out.
