Author Topic: Hardtop Lock Handle Loose  (Read 4457 times)
Typpo
  • USA, CA, Los Angeles
« on: November 25, 2024, 15:56:14 »
Hi all,
My hardtop's driver side lock handle is loose and it won't lock. The one that locks down the rear portion of the hardtop. It will swing out while driving. Is there an easy way to tighten this or do I have to remove/replace the entire mechanism? I've read posts about removing it and I want to know if that is necessary for just a loose handle that won't lock.
Thanks.
_________
Typpo
1967 Mercedes-Benz 250SL
1966 Ford Mustang GT Fastback
2019 Audi Q7
BobH
Re: Hardtop Lock Handle Loose
« Reply #1 on: November 25, 2024, 17:17:06 »
Have a look on here, page 6, it may help
https://www.sl113.org/wiki/Restricted/PagodaNotes?action=download&upname=PNv15i3.pdf
You may already have read this post, in case you need to take the latches apart
https://www.sl113.org/forums/index.php?topic=6856.msg43077#msg43077
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Typpo
« Reply #2 on: November 26, 2024, 01:29:34 »
No these don't help but thank you for your comment. The passenger side locks perfectly and I don't see any visual or functional difference between both sides including the chrome pillar caps. Puzzled.
_________
Typpo
2019 Audi Q7
Typpo
« Reply #3 on: November 26, 2024, 05:19:36 »
It just dawned on me that maybe my hardtop is sitting too low on the body and the latch's pin is not catching the chrome pillar cap. And i thought maybe the hardtop seal is old and flattening. So I searched the posts and I found it. https://www.sl113.org/forums/index.php?topic=2719.msg15207#msg15207
I am going to try the surgical tubing trick to puff up the seal. SO MUCH easier than replacing the seal. Even if it doesn't work, I will only spent a few dollars and a bit of my time. Thank you A Dalton!
Will report again.
_________
Typpo
2019 Audi Q7
Typpo
« Reply #4 on: November 29, 2024, 04:55:38 »
It was the old seal that became flat. Instead of surgical tubing, I just cut a piece pf neoprene rubber I had into a strip and inserted in the seal right below the latch. Now the latch locks. I will replace the entire seal when I get to it. For those of you having the same issue, hope this helps.
_________
Typpo
2019 Audi Q7
« Reply #5 on: November 29, 2024, 09:30:09 »
Good outcome and thought out interim solution.
I will move to Body area for future searchs.
AdelaidePagoda
  • Australia, South Australia
« Reply #6 on: December 12, 2024, 23:21:44 »
I have the same issue and will employ this clever hack to temporarily fix it. Not a major issue as I have only ever put the hard top on once in the past three years.
Dave
January 1964 230SL 4SPD Power Steering
050 050 Black Soft top, Red Leather interior
Italian delivered/ Germany/ Florida/ Boston/ Sydney/ Adelaide (5th owner)
Model S Tesla
Vespa
