Author Topic: All parts necessary for valve cover breather pipe?  (Read 1256 times)
Jack the Knife
  • USA, FL, Vero Beach
« on: December 04, 2024, 04:36:32 »
Hello gents, as my car is before motor number 010786, it seems I need at least the following to restore the metal breather pipe that went from the valve cover to the throttle body:
Throttle body end: https://www.authenticclassics.com/Metal-Breather-Pipe-for-early-230SL-220Seb-p/auth-007120.htm
Valve cover end: https://www.authenticclassics.com/Valve-Cover-Breather-Pipe-for-early-230SL-220Seb-p/auth-007122.htm?CartID=2
But I can't really determine what else is needed since there's so much variety in the photos I've seen -- some early cars have a rubber hose between the parts, others have a braided hose..
It seems many of these breather pipes were discarded in favor of venting to the ground, as was done on my car, likely owing to corrosion or other gunk inside of the line. It would be nice to have all the parts needed to restore this in one list, and I can add to the technical manual. I haven't seen any old threads addressing what actually is needed.
1964 230SL "Blue Note"
2015 G550 "Milk Truck"
hbrand
  • USA, FL, Edgewater
Re: All parts necessary for valve cover breather pipe?
« Reply #1 on: December 07, 2024, 23:22:46 »
The sleeve around all those breather parts is Nr.: 007 997 77 82
Greetings, Harold
Jack the Knife
« Reply #2 on: December 08, 2024, 01:27:11 »
Greetings, Harold
It seems that's for a later car, unfortunately.
I did remember I have not one for two parts catalogs, though no dealer catalog to tell me the part numbers.
I'm getting conflicting information wherever I look. It appears there are also some differences between the manual (my car) and automatic cars, at least according to the parts vendors, but that isn't reflected in the catalog.
« Reply #3 on: December 08, 2024, 09:58:06 »
If you provide VIN, I can look it up in the Mercedes system.
In the meantime, SLS have good pictures: https://www.sls-hh-shop.de/en/mercedes-230-280sl-w113/07-mech-injection-air-intake/09-air-intake-and-aircleaner
Part A007 997 77 82 was used in the range of M114 and M130 engines, so - later indeed.
Jack the Knife
« Reply #4 on: December 08, 2024, 21:34:12 »
Thanks for the offer, Pawel -- the VIN is 113042-10-009875
The first character is typewritten as an upper-case I but I assume that is supposed to be a 1. Motor number is 008394, titled and ordered as a '64 but I believe produced in March or so of '65.
« Reply #5 on: December 08, 2024, 22:40:10 »
Sure, enclosed. Yellow or green dots indicate availability at Mercedes dealers. Other dots - need to ask them. Prices may not be horrifying, worth checking.
"Przypis" means "Note", listed below.
"Zobacz zamienniki" is "Find interchange parts", I also listed, gave only previous part numbers.
Notes, parts for your engine:
A 127 010 03 70 | BREATHER PIPE Up to engine: 981 10/50,20/60 010786
N 915036 015101 Hollow screw, previous PN N 007623 013102
N 915036 015101 Hollow screw, Up to engine 981 10/50,20/60 010786
A 636 997 09 82 HOSE, Up to engine 981 10/50,20/60 010786
A 127 016 08 30 PIPE, Up to engine 981 10/50,20/60 010786
N 900269 020100 CLAMP, Up to engine 981 10/50,20/60 010786
A 127 094 04 91 BOOT, Up to engine 981 10/50,20/60 010786
N 916002 017100 CLAMP, Up to engine 981 10/50,20/60 010786
Notes, parts not for yours, for later engines:
A 615 997 00 72 Fitting, As of engine  981 10/50,20/60 010787 (after, not yours)
A 615 997 00 72 Fitting, previous PN A 180 997 21 72
N 000000 000667 Clamp, As of engine 981 10/50,20/60 010787 (not yours)
A 121 094 02 91 Cover, As of engine 981 10/50,20/60 010787 (not yours)
A 127 016 09 30 PIPE, As of - up to engine 981 10/50,20/60 010787 - 014471 (not yours)
A 127 094 07 91 BOOT, As of - up to engine 981 10/50,20/60 010787 - 014471 (not yours)
A 180 997 10 82 HOSE, As of engine 981 10/50,20/60 014472 (not yours)
A 129 016 00 30 PIPE, As of engine 981 10/50,20/60 014472 (not yours)
A 127 995 03 01 CLAMP, As of engine 981 10/50,20/60 010787 - 014471 (not yours)
N 000000 000667 CLAMP, As of engine 981 10/50,20/60 010787 (not yours)
« Last Edit: December 08, 2024, 23:47:50 by Pawel66 »
