Author Topic: 280SL Oil line fuel injection pump  (Read 543 times)
hbrand
  • USA, FL, Edgewater
« on: December 07, 2024, 23:18:27 »
280SL Oil line fuel injection pump.
Need new one or have to make one.
Greetings, Harold
Re: 280SL Oil line fuel injection pump
« Reply #1 on: December 10, 2024, 04:56:19 »
They are probably still available new from MB.
Vander
  • USA, OH, Columbus
« Reply #2 on: December 10, 2024, 12:10:26 »
I need one as well, so I contacted the Classic Center last week and they are discontinued. Part # 130-180-05-27
« Reply #3 on: December 10, 2024, 16:06:47 »
Several versions were used over the years. Earliest versions had a check valve in the line. Last version used a larger diameter tube. It depends on the IP. The pumps that lubricated by circulating engine oil, did not use the check valve. I suspect that the injection pump rebuilders might have a supply of good used ones?
hbrand
« Reply #4 on: December 12, 2024, 14:30:14 »
I will make a new one using the ends and soldering a new copper line onto the fittings.
Greetings, Harold
