Author Topic: Just finished another custom pagoda wiring harness creative stuff  (Read 489 times)
lpeterssen
  • USA, FL, Miami
Dear friends
As I see you read all my custom wiring projects, here after I describe one I just completed for a famous restorer in France on his customer request.
Apart from the usual stuff I do always this one requested some special things:
  • Master & Slave door locks.  This a simple system that allows you to open or close both doors locks by actuating on the driver lock cylinder.  If you insert your car key on driver door cylinder and open the lock, the passenger door lock will open at the same time.  Also if you push a buttom on a key fob remote provided both doors will lock/unlock
  • Hidden magnetic kill switch.  Many of you have commented that do not thrust, at all, into an alarm system since they are prone to failure; which in my opinion, is most of the time related to a low quality installation.  Nevertheless, these time the customer wanted a way to protect his car so we came up with the idea of a magnetic switch somewhere.
    This is a switch which is more than hidden that activates a signal when you place a magnet over it.  So we decided, in honor to the recent re-inauguration of NOTREDAM Church, to buy a small refrigerator magnet to place somewhere in a notorious place in the car, and behind it, is the magnetic activated switch.
    This switch is a Normally Open one, and when closed by magnet action, it sends a ground signal to an array of original mercedes relays that in place take some actions.
    One relay activates the fuel shutoff  selenoid at injection pump.  The other relay activates the low fuel reserve dashboard light.   Both relays only draw power when ignition switch is on the run position.  So this configuration will not deplete your battery when your car is sleeping.  User will know that system is enabled when low fuel reserve light is on once ignition key is turned to run position.
    For a burglar it is very difficult to resolve what is happening with the car that does not start; since fuel pump will be running, you will have spark, but car will not keep running. He may think is a matter of low fuel. It may start,  with fuel available in injection lines, but car will stahl immediately.
    So this is an ingenious way of protecting your car.
  • AC system. Customer also added the harness ai specially developed for pagodas to run on a modern AC system, with all the control logic of a W109-6.3 with some other add ons.
  • Stereo system.  Customer added a very nice French FOCAL amplifier/speaker configuration paired with a retrosound.com head unit.  It had some particulary high energy demands so the main harness was modified accordingly.  So branches for headunit, amplifier and power antenna were added to main harness.
  • USB charging points.  User wanted USB charging points at central wood console and in the dashboard.
  • Fridge /freezzer . This was also added in the trunk area, and a large 3mm2 line was embedded into rear harness.  Fuses for this line and the one that feeds the stereo amplifier were installed on the driver side fender at the engine bay area.
So this was a great project that I enjoyed so much.  Share with your friends
Detailed photos here
https://www.icloud.com/sharedalbum/#B2O5GV49auAnOa
Best regards
Eng. Leonardo Peterssen
Www.wiredoktor.com
« Last Edit: December 18, 2024, 10:51:38 by lpeterssen »
yves
  • France, Poitou-Charentes
Re: Just finished another custom pagoda wiring harness creative stuff
« Reply #1 on: December 17, 2024, 13:23:57 »
Bravo! 👍Well  done
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #2 on: December 17, 2024, 17:31:33 »
This setup sounds pretty cool.
A fridge/freezer in the trunk tells me that either this car will be used for longer outings or trips to the owner's favorite fishing hole.
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
Jack the Knife
  • USA, FL, Vero Beach
« Reply #3 on: December 17, 2024, 17:34:31 »
Sounds like really excellent work -- glad to have you doing this kind of thing in our community, Leonardo.
1964 230SL
2015 G550
RAY
  • United Kingdom, England, Bromley
« Reply #4 on: December 17, 2024, 18:40:26 »
What an interesting project completed to your usual high standard.
Bshaunessy
  • Canada, British Columbia, Invermere
  • 1957 190 SL; 1970 280 SL; 1975 450 SL; 1971 300 SE
« Reply #5 on: December 18, 2024, 03:53:19 »
Nicely done!🤙
« Reply #6 on: December 18, 2024, 08:15:50 »
Beautiful!
Do I see correctly? You both crimp and soldier the female spade connectors?
BobH
« Reply #7 on: December 18, 2024, 09:54:17 »
Well done yet again Leo, i love the fridge magnet idea
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
lpeterssen
  • USA, FL, Miami
« Reply #8 on: December 18, 2024, 10:37:18 »
Dear Pawel
So long without talking to you….  Yes I always crimp with a special tool and solder terminals just to have a perfect long lasting connection.
Thanks for your nice comments.
Best regards
Leonardo Peterssen
Www.wiredoktor.com
lpeterssen
  • USA, FL, Miami
« Reply #9 on: December 18, 2024, 10:38:58 »
Bob:
Many thanks , I also think that the Magnet / hidden switch was very creative and the implementation was perfect.
Best regards
Leonardo Peterssen
Www.wiredoktor.com
lpeterssen
  • USA, FL, Miami
« Reply #10 on: December 18, 2024, 10:41:21 »
Ray :)
Many thanks  for your positive feedback, specially mentioning my high quality standards……
Regards
Leonardo Peterssen
Www.wiredoktor.com
lpeterssen
  • USA, FL, Miami
« Reply #11 on: December 18, 2024, 10:42:23 »
Thanks Ives
In honor to Notredam….
Best regards
L.Peterssen
Www.wiredoktor.com
lpeterssen
  • USA, FL, Miami
« Reply #12 on: December 18, 2024, 10:48:20 »
To  :) Jack, Ray,  and Bshaunessy
Many thanks to you all for your positive feedback
Best regards
L.Peterssen
Www.wiredoktor.com
