Please check out joining the
Emergency Contact List
for help during your travels!
Electrical and Instruments
Mysterious Yellow Wire
Topic: Mysterious Yellow Wire (Read 467 times)
JayP
Full Member
Junior Level
USA, RI, newport
December 18, 2024, 18:52:12 »
HI, I'm trying to identify a yellow wire that passes through the firewall above the passenger side footwell. It has an in-line fuse on the side inside the car. There was a previous post (
https://www.sl113.org/forums/index.php?topic=17749.0
) with someone asking the same question about the same wire but no one identified it, so I'm asking again with the hope that someone might know. Thanks!
BobH
Full Member
Gold
United Kingdom, England, MALDON
Re: Mysterious Yellow Wire
December 18, 2024, 19:24:55 »
Hello, it isn't shown on the wiring schematics, and the fact it has an inline fuse would indicate it's been installed later, perhaps by a dealer
Have a look on here, seems Blaupunkt radios used a yellow power wire with inline fuse
https://www.sl113.org/forums/index.php?topic=2223.msg11714#msg11714
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
JayP
Full Member
Junior Level
USA, RI, newport
Reply #2 on:
December 19, 2024, 00:19:55 »
Thanks very much for replying. I do have an old Becker radio but it's working fine without that wire. Also that wire travels through the firewall and forward into a wire bundle, not to a fuse box. Still stumped. I will test it to see if it's live.
clunker
Full Member
Senior
USA, NJ, Chatham
Reply #3 on:
December 19, 2024, 03:23:15 »
Was there a/c previously installed? this wire may have come from the under dash a/c unit to control the compressor clutch.
Charles
1969 US 280SL 4-speed Red/Black
DB9 / 981 S / G300 SWB / CB750 / etc
JayP
Full Member
Junior Level
USA, RI, newport
Reply #4 on:
December 19, 2024, 21:30:10 »
Yes. According to the data card there was once a/c, although it's been without it for the 20 years I've owned the car so I forgot. That makes sense. Thank you.
