Author Topic: Fuel Injectors  (Read 1952 times)
Pengue
  • USA, CT, Fairfield
Fuel Injectors
« on: December 19, 2024, 17:27:37 »
Generally my '71 280 SL runs great but after sitting and idling for a period of time (5 minutes or so) it will stumble fall over itself when I accelerate.  Feels like just clearing excess fuel that may have built up in the piston chambers.  After 30 seconds or so of running very rough it smooths right out.  Could this be the fuel injectors?  I was thinking about having them pulled and doing a bench test to evaluate the spray pattern.
Any thoughts or similar experiences would be appreciated and what was the corrective action.
1971 Mid Blue (color code 350)
Automatic
4th owner
ctaylor738
  • USA, VA, Falls Church
Re: Fuel Injectors
« Reply #1 on: December 25, 2024, 13:01:17 »
Before going after the injectors, I would check the idle mixture and adjust as necessary, and make sure the car has non-resistor spark plugs, like Bosch W7DC.
Cheers,
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
Pengue
Re: Fuel Injectors
« Reply #2 on: December 26, 2024, 20:44:11 »
Plugs have < 1000 miles on them and are Bosch W9DC.  Part # 003 159 1003.  Got this info from Gernold at SL Tech in Maine.
Automatic
4th owner
Peter h
  • Germany, Rheinland-Pfalz, Enkirch
Re: Fuel Injectors
« Reply #3 on: December 26, 2024, 21:24:56 »
w9DC may be a bit too high.
I would also try w7DC or w5DC
What is the color of the spark plug?
08.68 280sl automatic white 717 G  blue MB Tex
09.68 280sl  4-speed, now 5-speed Getrag 180 G dark green MB Tex
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
Re: Fuel Injectors
« Reply #4 on: December 29, 2024, 01:16:01 »
I would ditch the Bosch plugs, I did so years ago and went to NGK's. Never going back.
Larry in CA
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
JohnnyC
  • USA, CA, Escondido, CA
Re: Fuel Injectors
« Reply #5 on: December 29, 2024, 01:36:53 »
I too ditched Bosch plugs years ago with my other cars also. My preferred is NGK (BP5ES for the 280SL). My first choice with all my other cars also.
Cheers and God Bless,
JohnnyC
John
'70 280SL (In Rebuild), Dk Olive/Cognac
'85 BMW Euro M635csi, Polaris Silver
'54 MG TF, Black
'01 Lazy Daze RV, White/Tan
'10 Genesis Coupe, Silver
'19 F150, Black
Re: Fuel Injectors
« Reply #6 on: December 29, 2024, 03:12:05 »
Generally my '71 280 SL runs great but after sitting and idling for a period of time (5 minutes or so) it will stumble fall over itself when I accelerate.  After 30 seconds or so of running very rough it smooths right out.
Would spark plugs cause an intermittent problem like this?  I would assume if the plugs were a wrong, they would cause a more consistent issue/symptom.
rosch
  • Netherlands, Gelderland, Halle
Re: Fuel Injectors
« Reply #7 on: January 06, 2025, 20:29:08 »
I would first do a quick check on the mixture at idle  by doing the split linkage test.
When your mixture is rich at a longer idle period this may foul your plugs ,especially right after a cold start when your plugs have not reached their optimum working temperature.. Running your engine at a higher rpm will often clear a (light) fouling after a short drive. Use the correct heat grade non resistor sparkplugs. NGK BP6ES generally work out nice. NGK BP5ES are slightly hotter and are recommended when (light) fouling occurs during normal operation .
Observing the color of your plugs tells you a lot about your mixture.
Tip : mixture and ignition problems  are easier to diagnose by using a so called Colortune (just google it).
This way I found a leaking injector causing me a lot of headaches over time. Mixture checks at any rpm and adjustments are easy to accomplish as well.
« Last Edit: February 10, 2025, 20:30:31 by rosch »
