Author Topic: fuel pump issue  (Read 2058 times)
Prestigiator
  • Île-de-France, Epinay sur Orge
fuel pump issue
« on: December 23, 2024, 06:46:01 »
My car is nearing the end of its lengthy restoration and I've had a strange thing when re-starting the engine after 6 1/2 years: no fuel pressure.
Fuel pump was running, there was petrol in the tank, but nothing arrived, no pressure in the engine bay.
I inverted the wires at the pump, thinkig it may help to prime it and bingo: there was fuel in the engine bay.
But after reverting to the corect electrical feed (plus from vh on the plus shown on the pump) still no pressure.
When I got the car, pump was normally plugged, with "+ wire" connected to "+" port of the pump.
It now runs, still with the pump plugged with the "+" wire on its "- " terminal.
Could anyone explain that?
Re: fuel pump issue
« Reply #1 on: December 23, 2024, 09:23:03 »
Seems you've disassembled the pump and upon re-assembly mounted the magnet cylinder 180° out. Very easy mistake to make.
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
Re: fuel pump issue
« Reply #2 on: December 23, 2024, 16:09:38 »
If looking at top of can the @ type symbol should be farthest away from the red terminal. See picture
Bob "Baron" Youngman
1965 220se coupe restomod
Re: fuel pump issue
« Reply #3 on: December 25, 2024, 06:10:25 »
Also check the main battery cables. If you reverse those, everything except the fuel gauge and fuel pump will work correctly.
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
Re: fuel pump issue
« Reply #4 on: December 25, 2024, 15:39:59 »
Wow! Joe, that is why you are the guru of W113 I would have never thought of that. That only comes from years of knowledge. You are such a asset to this group. Merry Christmas to all.
