Author Topic: Front flat sway bar springs A1123310012  (Read 4141 times)
Duncan200
  • 05-02-25 Just finished my Restoration
« on: January 02, 2025, 11:12:35 »
Looking for two of the flat stabiliser bar flat springs
Part number is A1123310012
Need to be 243mm long from centre of front bolt hole to middle of rear bush hole.
Trying to correct a Caster issue.
Thanks Doug
1966 MB 230SL DB 717 4sp Australian Delivered Matching Numbers Car. One day has come and she is back on the road
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
Re: Front flat sway bar springs A1123310012
« Reply #2 on: January 07, 2025, 14:24:49 »
I found where I sourced mine: https://www.kfz-schlachter.de/item/2011
These guys were very well aware about the length difference. The items were refurbished, in perfect condition.
I sent you PM, but put it here as well for others.
« Reply #3 on: January 11, 2025, 11:12:20 »
I dug through my cave and I found my springs. I have no idea what happened, I should have had 2 with different lengths, but I have 2 of 243mm (I hope I measure them right). No idea how it happened... could be I swapped with my mechanic who needs different sizes, just do not fully recall.
Anyway, if yo want them, send me a message with address, I will check the shipping - I would ask you to reimburse the shipping cost.
« Reply #4 on: January 11, 2025, 19:46:17 »
That is how I measured, hope it is correct.
