Author Topic: Lubrication  (Read 2007 times)
Lubrication
« on: August 06, 2005, 10:35:26 »
With the dash apart I would like to lube wiper assy, cables, levers.
Any suggestions or favorites for each?
Re: Lubrication
« Reply #1 on: August 06, 2005, 12:27:17 »
KGB, Lube the shafts that go from inside to outside with grease- had them freeze up on a 111 body-the pits!  90 weight in the cable runs. Your favorite grease on all hinging points/joints.  Not much space under the dash! Good luck.
