Author Topic: Deflector exhaust muffler  (Read 3272 times)
sens
  • Netherlands, North Brabant, Drunen
« on: January 11, 2025, 13:16:20 »
Hello there,
I am assembling a new after market exhaust system.
It looks like there is no deflector (some kind of tryangular protecting steel plate, No. 18) attached to the center muffler.
I could remove the old one and weld it to the new one, but my supplier says they never do that.
Should I weld it on and what is the exact function of it? Protection, strength, sound?
Thanks for your advice!
Halvor
« Last Edit: January 11, 2025, 13:21:55 by sens »
Halvor Sens
tcj
  • Germany, North Rhine-Westphalia, Lohmar
Re: Deflector exhaust muffler
« Reply #1 on: January 11, 2025, 15:04:35 »
The #18 plate prevents the protruding edge of the muffler from getting caught somewhere, especially if this happens while driving, then major damage can occur. I would definitely weld the plate on.
And it stabilizes the welding on the muffler
« Last Edit: January 11, 2025, 16:38:25 by tcj »
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #2 on: January 11, 2025, 16:44:45 »
Yes that plate is welded to the muffler. Mine has three spot welds that attaches it to front of muffler at the muffler seam
Robert Hyatt
Williamsburg, VA.
zoegrlh
« Reply #3 on: January 11, 2025, 16:50:31 »
When. Replaced the original tail pipes and muffler s with MB original replacement pipes, muffler came with the guard plate already attached.
Robert Hyatt
Williamsburg, VA.
BobH
« Reply #4 on: January 11, 2025, 17:13:45 »
Were these plates only fitted to 280's, can't see them on earlier cars?
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
zoegrlh
« Reply #5 on: January 11, 2025, 17:36:44 »
If you have excess to a parts catalog, look under the part number, might give you clue as to if and at what production number the guard was added.
Robert Hyatt
Williamsburg, VA.
« Reply #6 on: January 11, 2025, 18:19:16 »
A 113 491 00 92
They are present already in 113042.
