...a full "long block" rebuild. I want to work on it once...
Rodd, a noble quest! And, not for the faint of heart.
You might be reminded of the standards set by Metric Motors (who would do what you want to do in a matter of weeks, but for more than you probably want to invest). Here they are:
We understand that there are no shortcuts to achieving excellence in the remanufacturing of an engine built to the standards of Mercedes-Benz. From classic applications such as 190SL thru newer generation E350 we combine OEM parts with our stringent factory specifications to satisfy the expectations of the Mercedes-Benz enthusiast.ENGINES (AKA: “LONGBLOCKS”)Every remanufactured engine we supply includes the following:
NEW PARTS: PISTONS AND RINGS
ROD & MAIN BEARINGS
ROD BUSHINGS
OIL PUMP
TIMING CHAIN
CHAIN GUIDES
ROD BUSHINGS
CRANK SEALS
INTAKE VALVES
EXHAUST VALVES
VALVE GUIDES
VALVE SPRINGS
ROCKER ARMS / LIFTERS
CAMSHAFT NEW OR REGROUND
CHAIN TENSIONER
HEAD BOLTS
WATER PUMP (V8 APPLICATIONS ONLY)
COMPLETE GASKET SET (ELRING / O.E.)
REPLACE AS NEEDED OR NEW:TIMING GEARS, FLYWHEEL RING GEAR, MISC. STUDS & HDWR…
MACHINED TO EXACT FACTORY SPECS:BLOCK:
BORE & HONE CYLINDERS
SURFACE BLOCK DECK
ALIGN HONE IF NECESSARY
CONNECTING RODS REBUILT
GRIND CRANKSHAFT
SURFACE FLYWHEEL
BALANCE CRANKSHAFT ASSEMBLY
CYLINDER HEAD:
SURFACE
PRESSURE TEST
INSTALL NEW VALVE GUIDES / HONE TO SPEC
CUT SEATS / LAP VALVES
THOROUGH INSPECTION CLEANING AND DETAILING:
FINISH PAINT BLOCK AND OIL PAN TO FACTORY COLORS
PLATED HARDWARE WHERE APPLICABLE
TAP AND REPAIR ALL THREADS
METICULOUS ASSEMBLY
_____________
You have a long shopping list if these standards are what you would like to achieve. May I suggest you keep a running thread for all of us wanting to see the progress, illustrated.
