Author Topic: low risk method to remove a pilot bearing quickly and easily without a puller  (Read 794 times)
roymil
Since I didn't find anything about it on sl113, I thought I'd share this link to the bread method.  I just used it to remove my pagoda's pilot bearing without a puller in just a couple minutes. Crazy idea, but it sure worked well with no damage to the bearing or cover.
a super short video explains itself :  https://www.youtube.com/watch?v=nkRmKWktW70
Mark Miller
1968 280SL
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
ha! great idea! I removed a pilot bushing that way a few years back on a small block, but I used grease instead of bread. Bread wouldn’t have made such a mess! Thanks, Charles
« Last Edit: February 17, 2025, 00:13:16 by Charles 230SL »
clunker
  • USA, NJ, Chatham
I have debated using this bread method, but with a basic inner bearing puller being fairly cheap I would have thought that would be simpler/less messy. Any particular reason to prefer one method over the other?
Charles
1969 US 280SL 4-speed Red/Black
DB9 / 981 S / G300 SWB / CB750 / etc
roymil
I didnt happen to have a puller that small and I was also a little concerned about deforming the cover, which I now see is pretty thick, so unlikely the puller would have done too much damage. Using bread was low risk so I gave it a try with great result.
Mark Miller
1968 280SL
ejboyd5
  • Southold, NY
It's always refreshing to see tried and true solutions being passed on the next generations.
sandcrab59
  • USA, MA, Lunenburg
I have pulled pilot bearings with a small puller in the past  but this bread idea looks great.
When I pull another one I will try the bread routine.
Tom M
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
