Author Topic: 230SL Horn contact plate  (Read 268 times)
Brandini
  • USA, WA, Seattle
« on: February 26, 2025, 04:04:36 »
I have been having issues with my horn not working and can't seem to figure out the issue. After removing the steering wheel and inspecting the contact plate I noticed that there is only one wire going to the contact plate (see picture) - is this correct? Or should there be another wire?
Also, I noticed that one of the tiny springs is missing. Can I order this part or is it better to buy a new contact plate altogether?\
Appreciate the help! - Brandon
Brandon
1964 Mercedes 230SL
Seattle, WA
BobH
Re: 230SL Horn contact plate
« Reply #1 on: February 26, 2025, 16:37:13 »
Hello Brandon, i don't know what springs or other components are on the switch contact plate, but have a look on here for some details and clear pictures, perhaps someone who has had theirs apart may comment
https://www.sl113.org/forums/index.php?topic=33714.msg246918#msg246918
Two wires should come from the column switch, if you pull the switch off of the column and expose the connections, you'll see a brown wire and a black/yellow/pink wire.  A brown wire should go from there to one side of the horn connection, and another wire, either black/yellow/pink or just black should go to the other connection on the plate
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Brandini
  • USA, WA, Seattle
« Reply #2 on: February 26, 2025, 17:06:40 »
Thanks Bob this is very helpful.
Looks like I am going to have to take off the turn signal switch to see if I can find the other wire you mentioned as I don't see it.
Brandon
1964 Mercedes 230SL
Seattle, WA
BobH
« Reply #3 on: February 27, 2025, 22:30:19 »
Just found this post, your early car may have a slightly different horn contact arrangement, although the wiring will be the same
https://www.sl113.org/forums/index.php?topic=18528.msg129278#msg129278
« Last Edit: February 27, 2025, 22:37:08 by BobH »
UK delivered RHD
Blue soft top
Blue leather
