Author Topic: Piston Ring set (18) for engine block number 130.980-12-047632  (Read 51 times)
SuperRobbieG
  • USA, PA, Malvern
I have a 1965 Mercedes 230SL Pagoda with a non-original engine block number 130.980-12-047632.  I believe it’s from a late 60’s/early 70’s 280SE (W108, W111) which had a 2.8L inline 6 cyl.  I am looking for the following:
•   1 ea. Piston Ring Set (3 rings for each piston)
Thanks for any assistance.
The only part number I found for this engine is
A 001 030 04 24 PISTON RING PARTS KIT
As of engine 980 12 061152
So for later engine.
Yours would be A 000 030 90 24,  As of engine 980 12 042380, which is NLA.
You would have to check somehow if they fit.
These are part sets, 4 rings each, actually.
