Author Topic: Water in Trunk and Petrol on Bumper!  (Read 4554 times)
« on: August 09, 2005, 03:38:13 »
Hello all,
I noticed that whenever I wash my car (by hand or at the carwash) i end up with a considerable amount of water in the trunk). I changed the trunk seal but that did not take care of the problem.
Also, i always notice a stain of fuel on the rear bumper just under the tank opening. I changed the rubber seal and the gas cap, but the problem still persists. Any suggestions?
Mo
'69 280 SL Silver/Black
Re: Water in Trunk and Petrol on Bumper!
« Reply #1 on: August 09, 2005, 18:35:30 »
Hi Mo,
Check that the rubber seal around your tail lights is good.  I had to replace mine, most of it gone.  Now...  no water in trunk!
Memphis, TN.
1997 E320
« Reply #2 on: August 09, 2005, 18:56:53 »
Mo,
I agree with Bob. Check those tail light gaskets. They have a way of getting forgotten during restoration work.
Also, try not to linger with the hose around the tail lights when washing the car.
Finally, make sure the trunk fits properly. Does your trunk lid have the round bumpers on either side of the inside lip?
« Reply #3 on: August 09, 2005, 20:01:12 »
As far as the gas stain, do you notice a whoosh sound when you open it to put in gas? There are a number of threads on this issue, mostly related to plugged (or detiorating)hoses and/or plugged metal lines for the small vents on the gas tank (under the cover- inside the trunk partially blocked by the spare tire). On those cars with the spare tire mounted on the right side that is.
erickmarciano
  • Canada, Quebec, montreal
« Reply #4 on: August 09, 2005, 22:14:41 »
same 2 problems on my car, sorry I am no help
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
« Reply #5 on: August 10, 2005, 03:44:06 »
Me too!
Although my water seems to accumulate in the trunk lid too - so gets into the trunk when i open it. This appears to be from the decals through the back of the lid. However, I also get water under the mat...
Made a ticker rubber gasket for the fuel cap: the problem is not gone - and the cap tougher to fit -  but it stops quite so much fuel pouring over the road (at 90p a litre)
« Reply #6 on: August 10, 2005, 04:34:03 »
One thing I've learned to do is never to top off my tank when filling it.
« Reply #7 on: August 10, 2005, 07:13:16 »
Yep I've got those problems too ! Definitely the badges leak water into the framework which falls down when you open it. The lamp gaskets leak if they aren't good or tight and I believe there is more than one way to fit the trunk seal, one of which is incorrect and results in a leak........noty sure how to do it though !
My fuel filler will stain the bumper too, but as mentioned its only when the tank is really full !
« Reply #8 on: August 10, 2005, 21:56:27 »
Can you apply some marker (chalk?) to the trunk seal, close the trunk, open the trunk, and see if the chalk transferred to the trunk lid, indicating a seal/trunk contact?
For the fuel, make sure you have the right cap (vented/non-vented).  This has been discussed, search for it.  Also, when you lock the cap (assuming you have a key locking cap) then you should be able to freely spin the cap.  This indicates it's properly seated.
Cortez-Campos
« Reply #9 on: June 05, 2006, 16:05:00 »
I have 2 problems
1 -  I also have this problem with petrol on the bumper, as Ben says it is only when the tank is full, but it can't be true we can't fill up our gas tanks. I don't know what Rodd means by vented/non-vented caps, mine is without key, does anyone have a smart trick?
2 - I just bought a used gastank from another 280 SL, and it is a 82 liters, but I can only fill in 60-65 liter.
280 SL 1969 anthracite 172, with red inteior.
« Reply #10 on: June 05, 2006, 16:15:52 »
I used to have a small amount of water in my trunk after I washed the car.
I cured this problem when I replaced both tail light rubber seals.  I think that this is often over looked, especially if the trunk seal is good.
« Reply #11 on: June 05, 2006, 20:07:36 »
Originally posted by Cortez-Campos
I don't know what Rodd means by vented/non-vented caps....
http://index.php?topic=2341,gas,cap
http://index.php?topic=1679,gas,cap
http://index.php?topic=1605,gas,cap
http://index.php?topic=1310,gas,cap
http://index.php?topic=270,gas,cap
