Author Topic: Wheel cover painting recommendations  (Read 1289 times)
Alf
  • England, Surrey, Lightwater
« on: March 16, 2025, 11:27:22 »
I have a spare set of 280sl wheel covers which I’d like refurbishing and repainting. There are a few paint chips. Any recommendations in the UK where I could get these done? These were the ones originally on my car when I bought it. I had new ones about 15 years ago but the quality isn’t as good. The originals feel heavier.
Alf
'69 280SL. Silver (180 G) with black hardtop
Re: Wheel cover painting recommendations
« Reply #1 on: March 16, 2025, 12:02:18 »
Any body shop SHOULD be able to do this for you.
Originals were chrome plated steel. Replacements (I don’t know when the change was made) are high quality polished stainless steel, which are a tad lighter. I’m only talking OEM from MB.
Then, there are reproductions out there made of a lower grade of SS and are lighter still.
« Reply #2 on: March 16, 2025, 16:48:24 »
That depends on how authentic you want the finish to be.
A bodyshop that knows these cars will know that the factory used a stencil that gave a soft edge to the paint.
Amateurs will mask them with tape and get a hard edge. The difference is either tiny or huge, depending on your requirements.
« Reply #3 on: March 16, 2025, 19:27:06 »
For those so inclined that they must have that soft edge, one can always buy one or a set of these stencils.
https://www.authenticclassics.com/Painting-Stecil-for-Wheel-Cover-for-280SL-p/auth-007750.htm
I'm sure a shop would welcome a customer supplying a stencil, it would save 30 minutes per wheel cover easily, in masking.
Mine were painted by perhaps some of the most professional painters out there...hardly amateurs...but they masked them by hand. Nobody has ever critiqued the results of the wheel covers and the car has been judged many times.
With or without a stencil it's not a big deal.
« Reply #4 on: March 17, 2025, 05:30:57 »
Preparation is key. I used to slightly sand blast the areas to be painted to give the paint good grip. Then I used a good self_etching primer to get really good adhesion to the chrome or stainless surface. If you are not using the stencil, the secret is to use as little paint and primer as possible, which will leave a softer edge. The primer should just be a slight mist coat then use just the minimal amount of paint to do the job.
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #5 on: March 18, 2025, 14:02:25 »
Do the club have the stencil at one time. Seen to me that it was sent around from time to time.
Robert Hyatt
Williamsburg, VA.
doitwright
  • USA, IL, Willowbrook
« Reply #6 on: March 22, 2025, 03:18:54 »
The stencil can be a challenge for even an experienced painter who has not used one before. Transferring the stencil from one cap to another during a continuous process can have messy results. Also, marking the stencil so it gets placed on the same point of the star during each primer, paint and clear coat step should be part of the process.
Frank Koronkiewicz
Willowbrook, Illinois
« Reply #7 on: March 22, 2025, 13:42:13 »
...and while all this "fussing around" is being done, the good body guy/painter has masked two wheel covers already...
Some years ago, former member here Tom Rose from Idaho and I, both with 568 Signal Red cars, and both with new wheel covers, teamed up. He sent me his wheel covers, and I took them to one of the best body shops in SE Michigan. $300 and all 8 wheel covers were done...they were not interested in pursuing a stencil method.
dirkbalter
  • USA, CA, Corona
« Reply #8 on: March 22, 2025, 16:27:51 »
Stencils didn't work for me either. As mentioned below, the work is in the preparation.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #9 on: March 22, 2025, 16:47:20 »
I have done this several times. Dirk is spot on, preparation is the key. If you do this, remember to get the tape off relatively quickly, as the finish will crack if you let the paint dry completely. You have to be careful to watch where your fingers go, as you could leave fingerprints in the slightly wet paint.
dpreston Virginia
  • USA, VA, Salem
« Reply #10 on: March 22, 2025, 18:07:09 »
I had good luck with the stencil.
Here is the link to my project:
https://www.sl113.org/forums/index.php?topic=27187.msg194898#msg194898
190SL 1960 Sold
280SL 1969
280SE 1969 cabriolet
Vette 67
Porsche 912 67
