Vince,
Yes , I have a Mod Attachment from Benz on that somewhere here .. prob the same one you have in the later Service Manual.
Anyway , lossening of the bolt was a common problem, so the loctite used is their specially formulated 243/oil resistent , mild lock w/removable strength. Not the High Strength old stuff, of course..
It is on their web site and is specially formulated for such an application with no fear of breakage at removal, if ever needed. Correct tool/Correct compound.
I just use a tiny bit and do not do the splines . As long as the bolt can't vibrate loose , should be fine. Might also consider a new lock washer. I also use the same on the rear pin nut of the trannies for the same reason, Another common loosening problem part.. there is a current thread here somewhere on that one too.
* Added note* on tranny nut torque ,while I am at it.
Be aware that these tranny output flange nuts on the stick shift types have been known to have re-occuring loosening problems b/c the installer , even though he uses both a new lock plate and the proper pin wrench [ instead of hammer/punch] mis-takenly torques the nut to the auto tranny torque of 87ft/lb - 108Nm. The Manual tranny spec on this part is actually higher than the auto , it is 108 ft/lb.-150Nm..
Just a heads-up on an often overlooked spec that can easily result in the potential of the same problem down the road..
