Hi all, after recently acquiring a Frigiking A/C system I am seeing if what I have bought works. I am giving the under dash unit a strip down and testing on the kitchen table to the disapproval of the Mrs. Can someone familiar with these units give my some advice. I have searched lots of posts on the forum but none answer my question. The light illuminates but does not go off, the fan runs on all three speed setting but will not turn off. I presume as the fan does not turn off, this switch also controls the light.
Also is it normal that when the Temp switch is in the off position the fan does not run in any speed. If I need a new switch is there a plug and play replacement available.
Many thanks
