Author Topic: Standard Transmission Tour  (Read 11255 times)
« on: August 09, 2005, 20:26:44 »
You guys are right we need the new topic so all this current information is not lost in irrelevant strings. I can start "the tour" here with pictures this week end. In the meantime pile information on this topic.
Re: Standard Transmission Tour
« Reply #1 on: August 09, 2005, 20:31:07 »
Previous relevant information :
"Posted - 09 Aug 2005 :  17:10:19
Hey Arthur and Joe,
Thanks for the replies.
I think SteveRen is right, this discussion should be a separate topic.
There is a lot of important info here that shouldn't be lost in an un-related discussion.
Greg,
don't despair!
Edited by - hands_aus on 09 Aug 2005 17:11:58
enochbell
Regular Level
 Posted - 09 Aug 2005 :  14:21:20
You know, I am quite sure my car was in much better shape before I started reading this board...
I also have the speedo needle bounce. Assumed it was the speedo, now I wish it was that easy. It is no problem when ambient temp. is cold (below 50 F) but it is sluggish when hot (not the car, the ambient temp.) The speedo works well @<40mph but in higher ranges is will fall off and show 10-30 mph less than actual speed, and it works accurately only under hard acceleration. Sounds like the speedo drive gear is slipping?
I'm goin' in. Should I have on hand shims for the input shaft or should I try first to just tighten the nut? I will replace the trans. mount while in there, are there other maintenance items I should attend to while I am at it?
Thanks for the advice,
Greg
SteveRen
Junior Level
 Posted - 09 Aug 2005 :  13:30:52
Hey Everyone...
Maybe this should be a new topic, and if so, do advise...but i read the part about the bouncing speedo needle and i have been told that the same problem exists with th evehicle i am currently investigating for purchase( 1964 230SL 4spd euro). Is there something else i should be looking for?
Thanks in advance.
Gold Level
Canada
 Posted - 09 Aug 2005 :  13:12:18
Getting the end play set on the input shaft is what makes the trans shift smoothly. Any end play and the shaft moves before the syncro starts to work. This can cause the trans to jump out of gear but most of that is caused by a worn input shaft. The end where it fits into the pilot bearing can have no wear which is caused by a siezed pilot bearing and/or too much end play on the shaft. This movement can cause a deflection to occour on the main shaft which will sometimes make the trans pop out of high gear under load.
There are a number of small shims onder the front cover plate which need to be added to get the end play set to about .001''. I've seen them as much as .030'' or more.
Gold Level
 Posted - 09 Aug 2005 :  11:17:21
Originally posted by Raymond
Dalton, the pin socket I bought is from SirTools.com. I can't remember the part number and there aren't any markings on it. It was the only one they showed. I originally got the tool part number from Naj. I believe he had purchased and used one so it must have been right for his car.
'68 280SL 4-spd Coupe
The problem one runs into with this pin socket is all the manufactures list them by auto trans type. No mention of manual , so this is the cause of the confusion...
So , guys sometime order the late K4C-025 one , when it is the earlier K4A -025 auto one that fits our manual trans nut.
So , whichever manufacturer one uses , make sure their listing is for the K4A/025 trans and it will be the correct stick one .
The pin for rear diff is the same for all swing axles, so one never winds up w/imcorrect one , as it is the only one...
You would think that they would mention this difference , but they do not..
If one has a late .044, the K4C-025 auto is correct. I believe that would be after the '69 break line..
It is not uncommon to see a posting where someone orders this tool and winds up with the one that does not fit ...50/50 chance, anyway. They then wind up making there own . .. which is way better than the punch technique :)
I think on the sticks , a little LockTite might be in order. too..
Edited by - A Dalton on 09 Aug 2005 11:33:11
Gold Level
United Kingdom
 Posted - 09 Aug 2005 :  08:14:57
standard transmission "tour"
While on the subject, is a 4 speed with floor shift from a 220Se same as a Pagoda box?
I was given one by a club member. Externally, it looks the same except the change speed lever on the top cover is horizontal instead if 'angled' downwards.
Edited by - naj on 09 Aug 2005 12:28:14
Gold Level
Ireland
 Posted - 09 Aug 2005 :  06:59:17
On a standard transmission the tightness of the nut keeps the entire main gear cluster tight. If the nut should come loose so does the gear cluster, causing a bouncy speedometer (especially under acceleration and de-acceleration). Often some shifting problems will follow (slight nipping when going into gears or hard shifting). The problem on the standard transmissions is once the cluster becomes loose enough it will shift a key out of place and then just tightening the slotted nut may not completely solve the problem.
Bad synchronizers are usually blamed for the bad shifting, this is rarely the case!
.............a Tour would be really usefull ! I tried to rebuild my tranny afew years back and it wasn't succesful! I had the speed o bounce problem, I had some noise and "Jumping" out of 4th !
I opened it and didn't see to much wrong, I replaced the bearings and synchro rings ...........I saw that key way you mentioned Joe...
but it still felt the same when I put it back together ! I later replaced the output flange nut and lock plate, having borrowed the tool from Naj.
I now see the speedo doing its trick again and I have a spare standard tranny which I want to rebuild then swop in ! Any info would be great here !
Gold Level
United Kingdom
 Posted - 09 Aug 2005 :  04:26:20
The one for the gearbox is M0029.
The nut on the diff is different and uses M0030.
Gold Level
 Posted - 08 Aug 2005 :  23:04:28
Hello Bob,
The problem is a lot less likely on automatics. But I have seen it. It is ususually a result of improper installation of the slotted nut on the automatics after rear transmission seal replacement and/or flange replacement.
The brass speedometer drive gear for both the auto and std. transmissions has no key or spline and depends on the tightness of the nut to keep them from slipping!
The slotted nut should be checked for tightness when repairs provide an opportunity or problems occure. There is a sheetmetal lock plate for this slotted nut, which should be replaced at these times.
I will try to do a standard transmission "tour" soon, since there is little information posted on these units. Stay tuned!
Raymond
Regular Level
 Posted - 08 Aug 2005 :  22:40:55
Gold Level
 Posted - 08 Aug 2005 :  18:37:28
BS,
It does not seem to be , but ..
Don't have a solid answer for you as to why , just seems to be the case.
If any auto trans guys here have had the same problems as many of the stick guys have had with this common problem , be nice to know ..
..prob has to do with autos upshifting auto under load ???
or, maybe even a better tail shaft spline fit ??
*An added note here .
Many order the pin wrench and it usually winds up the wrong fit .
Well , seems there are two different ones , so make sure before you order one..
Gold Level
Australia
 Posted - 08 Aug 2005 :  15:47:31
Arthur,
Is this flange nut not a problem on the autos?
Bob Smith (Brisbane,Australia
RHD,1967 early 250 SL, auto "
« Reply #2 on: November 24, 2005, 08:20:47 »
Does anyone have any photos of gearbox parts ?
The usual "tour" with photos would be great here, you see we've been spoilt !
« Reply #3 on: November 25, 2005, 10:37:00 »
Hello Ben,
Ok, I have a gear box ready to tear down. Soon as I get throught the "Wheel Bearing Tour" we will begin! This week end possibly.
« Reply #4 on: November 26, 2005, 07:47:40 »
Hello, Joe,
220 Gearbox I was talking about:
Casting # 111 261 0501
Download Attachment: Gbx220-10.JPG
53.32 KB
Download Attachment: Gbx220-13.JPG
42.01 KB
Sir Tools M0029:
Download Attachment: Gbx220-15.jpg
33.36 KB
« Last Edit: November 26, 2005, 15:07:38 by naj »
« Reply #5 on: November 28, 2005, 04:30:10 »
Great stuff Joe.........looking forward to it !
Naj that look identical to the 113 transmission. I have a spare so I could check those numbers if you want !
« Reply #6 on: November 28, 2005, 06:32:23 »
Ben,
Yes please!
Also check the change-speed lever - the one with the big hole.
It may be angled down???
« Reply #7 on: November 28, 2005, 11:24:19 »
Chad
Ref your wish list Item 4)
5 speed transmission (just kidding, but there are probably some common repair parts that you lucky dogs with the ZF could use)
Here's one developed by H K Engineering for the 300SLs:
Download Attachment: Esn091.JPG
43.04 KB
Download Attachment: Esn092.jpg
36.23 KB
We did enquire about the possibility of producing one to fit the Pagodas but no response todate.
« Reply #8 on: November 29, 2005, 07:21:41 »
Naj the top rod attachement is bent down on the 113's. I have read that the top cover should be changed over, maybe this is why !
Either way I will dig it out and take photos/check numbers but it could be a day or two ok !
« Reply #9 on: November 29, 2005, 11:18:44 »
Hello Ben,
Yes many of the sedan transmissions are identical except for the gearing, sometimes just first gear. You can look up the gear ratios for all the gears in the Technical Data Booklets. The easiest way is to remove the cover and simply count the teeth on each gear if you are not sure what you have. Many of the sedans had a very low first gear.
The Top cover is different on the W113 as the shift rod "goose necks" downward to clear the tranmission tunnel. These cavers are interchangable.
« Reply #10 on: September 03, 2008, 17:32:57 »
Joe,
Were you ever able to put this together? I was starting to put together the next newsletter and this looked like a good next step in the chain.
« Reply #11 on: September 05, 2008, 19:46:33 »
Hello Jonny,
Actually George Davis and Jeff C. did such a good job with this string   http://index.php?topic=6222,transmission  that I felt no need to go much further.
However I do have some additional information I think is important, I will email it off to you and maybe we can finish up a tour.
« Reply #12 on: September 06, 2008, 13:48:18 »
Thanks Joe, I will have plenty of airplane seat time (and some hotel time) over the next couple of weeks, so I hope to get the next issue of notes put together. If you are swamped right now, I can proceed to one of the other collections of tours.
« Reply #13 on: September 06, 2008, 22:24:13 »
Hello Jonny,
Alfred and myself have combined to  produced most of the information for a "Valve Adjustment Tour" also.
