Author Topic: Manuals or Drawings of Stromberg 175CD Mercedes Model Wanted  (Read 341 times)
Since a lot of you have wide knowledge of many classic Mercedes models, I have a kind request for help: I am in need of manuals or drawings of carburetor Stromberg 175CD (as on the picture). These carbs were installed (mainly with automatic choke, but it is not an issue) in:
MERCEDES /8 W115 230.4 115.017 kW 81 / 08.1973 -12.1976
MERCEDES /8 W115 220 115.010 kW 77 / 01.1968 -07.1973
MERCEDES /8 W115 200 115.015 kW 63 / 01.1968 -01.1977
MERCEDES /8 W115 200 kW 70 / 01.1968 -01.1977
MERCEDES /8 W115 220 115.010 kW 66 / 01.1968 -07.1973
and engines
M115.938, M115.939, M115.954
I think also in M102.
All I have is exploded views from Mercedes parts lists. I have manuals for a different version of this carburetor that enabled me to tune the engine. But I do not have a manual for mine. I need it to establish how to seal the place marked with an arrow (I had a leak there when the float chamber valve got stuck with debris). The "thin chimney" on the picture, held by hand, would also be ok as it has the same choke solution as mine. My theory is that the marked place is the choke air inlet, but I am not sure, need to verify.
I need information on how mine is built to see how to seal the marked place.
