Author Topic: Is safe to use scissor lift type ?  (Read 1794 times)
mauro12
  • Italy, Sicily, Messina
« on: April 12, 2025, 10:30:44 »
Hello guys , I know this topic has been discussed in the past but i want to be 100%sure .
Since im going to replace tires and all tire shops here uses scissor lift type , my question is , how safe is to lift our car in that way ? Our car doesn’t have structural lift points in the frame rail like modern cars . I don’t want to risk and damage something . The lift points are very internal and not external like modern cars  as I said .
What do you suggest ? Thank you
Mauro Pisani
250sl 1967 5speed zf manual
Duncan200
Re: Is safe to use scissor lift type ?
« Reply #1 on: April 12, 2025, 11:57:38 »
Just make sure they use rubber blocks and locate them on the lifting points.
If I was placing my car on a scissor lift, I’d place one block on the “rails” at the front and one under the rear trailing arm pick up points on the body.
Doug
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
EeVeeWee
« Reply #2 on: April 12, 2025, 15:36:05 »
I use a hydraulic driven scissor lift for several years now and i'm very satisfied.
Just make sure you buy one with good quality and with safety items as mechanical blocking or one with check valves together with an extra safety valve.
Also use rubber blocks underneath the chassis to lift the car.
Again something else.
BobH
« Reply #3 on: April 12, 2025, 16:10:59 »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
mauro12
« Reply #4 on: April 20, 2025, 21:43:07 »
Thank you for you help . Yes is quite clear where our car can be lifted . My personal thought is that with a scissor lift type , if you place a rubber block in the front you have to put under the structural frame rail , which is located almost in the middle of the car . Since the platforms of the lift cannot be moved laterally, perhaps they don’t match with the rails of the car . That’s my understanding.
Mauro Pisani
Figoulu
  • France, Languedoc-Roussillon, Villeneuve les Avignon
« Reply #5 on: April 21, 2025, 09:58:25 »
Here is what I’m using and the way I can lift my 230…
1965 230 SL
1991 Porsche 911/964 carrera 2
My youtube channel #lfgdf
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
« Reply #6 on: April 27, 2025, 21:50:31 »
Hello All,
      I've had one of these AutoStacker scissor lifts for several years now and believe it as the best on the market.
The welded sub-assemblies are (of course) Chinese origin, but the design, the electronics and the quality control comes out of Los Angeles and are first rate.
Larry in CA
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
mauro12
« Reply #7 on: April 30, 2025, 18:16:14 »
Hello guys , as you can see from the picture , today i replaced my 20 years old tires with the new one. Regarding the lifting points on the front , they have putted 2 big rubber blocks just under the factory  jacking hole and it seems to be ok . The lifting was very solid with no issues . Obviously is better to use rubber blocks rather than wood .
Mauro Pisani
mauro12
« Reply #8 on: May 01, 2025, 20:59:42 »
Have you ever seen how is structured the front jacking hole of the car ? The hole where the jack is supposed to be inserted to lift the car .
I suppose the whole part under the jacking hole , should be strong enough to support the car . In my case with a big rubber pad .
Mauro Pisani
