Author Topic: big mistake... [updated: no 😇]  (Read 1711 times)
Figoulu
  • France, Languedoc-Roussillon, Villeneuve les Avignon
« on: April 14, 2025, 12:53:18 »
Hello all
I was happy to get my engine overhauled and before putting it back in the car I checked various elements, from which the valve clearance.
Suprisingly almost none was correct, and I checked twice so happy to have made the chekings as the engine was outside
I put everything back inside the car, put oil, check again all the wires and connections and tried to start the engine.
Half a second later the engine was stuck as if the battery was dead.
I understood quickly that some pistons met some valve...
I figured out that as my head has been machined, the thickness of it is different so as the valve clearance. Actually I understand now that the original clearances were correct...
Now what to do ?
I sent an endoscopic camera. Nothing bad so far from what I could see. The engine only turned 1/2 a second.
I want to remove the head and see what to cure.
Probably I will need to cut the timing chain to be able to remove the head, unless I can remove the camshaft gear as well as the belt tensioner to let it go
Once this will be solve what shall I fear as damage ?
I assume only the head as to be checked, what about the block and the rest of it
I'm really stupid... but that's the costly way to learn
« Last Edit: April 18, 2025, 18:46:47 by Figoulu »
1965 230 SL
1991 Porsche 911/964 carrera 2
1990 Porsche 911/964 carrera 4 SOLD
2020 Harley Davidson Fatboy
2018 Harley Davidson Street Bob SOLD
2003 Harley Davidson Road King Classic SOLD
2017 Harley Davidson softail Slim SOLD
2008 Harley Davidson Softail Fatboy SOLD
My youtube channel #lfgdf
Re: big mistake....
« Reply #1 on: April 14, 2025, 13:52:45 »
Engine is build-in  again: then I would set de clearance correct and see how the engine performs.
Alternative is, what also will happen when the engine does not perform nicely, is again a complete overhaul, as the crankshaft could be (minimally) bended, the crankshaft bearing can be “oval”, valves bended,  etc…..
I know, a horror scenario. Sorry for this.
Re: big mistake....
« Reply #2 on: April 14, 2025, 14:21:20 »
I would not expect the skim of the head would be so much that setting the valve clearances to original specifications would cause the valves to hit the pistons. The machine shop would have had to remove a lot of material.
 What I would do:
- try turning the engine by hand after removing all spark plugs
- double and triple check the engine timing: valves vs pistons vs ignition
- if engine spins freely by hand then use the starter to spin the engine briefly
- try starting it again, if the engine spins freely
Could it be that there is 'something' obstructing the free movement of the engine, such as a wrench, the timing chain, a loose bolt somewhere?
Figoulu
Re: big mistake....
« Reply #3 on: April 14, 2025, 14:45:48 »
 What I would do:
Impossible to turn the engine even with the spark plug removed... in one way and in the other way
I have no idea if something else could have blocked the engine... yes could be a nut, but nothing like a tool, I don't believe that
I guess the only way to see more is to remove the head, but there might be a way to loosen the head and remove the timing chain other than to cut it. With removing the camshaft gear ??
I forgot to mention that the endoscopic camera shows the very slight print of a valve... But I agree with you, how could the machine had potentially removed so much "meat"... so that the valve met the pistons
Before doing all this I had checked the timing and everything was well synchronised...
« Last Edit: April 14, 2025, 14:50:46 by Figoulu »
1965 230 SL
yves
  • France, Poitou-Charentes
Re: big mistake....
« Reply #4 on: April 14, 2025, 17:18:55 »
What about à timing chain opened ? And blocked ?
MikeSimon
  • USA, OH, North Royalton
Re: big mistake....
« Reply #5 on: April 14, 2025, 18:13:26 »
I would guess that the cam chain was not installed properly and a valve protrudes into the cylinder when the piston is at TDC and caused the interference. The head comes off from the engine with the engine installed. It is a hassle, but not a problem.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Figoulu
Re: big mistake....
« Reply #6 on: April 14, 2025, 18:53:47 »
How about the chain ? How would you remove it ? Shall I remove the camshaft gear ?
As far as I remember the timing was ok. I checked it when doing my valve clearance
1965 230 SL
Re: big mistake....
« Reply #7 on: April 14, 2025, 23:42:47 »
Bummer to hear that.  I would take cam cover off and look at the valves to make sure all of them are still in place(not dropped).
Then do like others said, remove plugs and try to turn by hand.
If nothing, mark location of camshaft to chain sprocket wheel and make sure you don't loose timing marks.
If the camshaft is in wrong position(180 degrees) off from crank, then the timing is all off.
Reset by turning the crank and camshaft independently till you line them up properly.
You said you spun the motor briefly, then you should be ok with unbent valves and uncompromised pistons.
I don't know how much you spun the motor before locking up.
Go ahead and cut the chain and remove head.  New chain and head gasket is in order.
Have head and valves fixed(pressure test).
Bought a 1970 280SE with the timing turned 180 degrees off and the valves were trashed.
Got a new motor and installed it, with no problems.
That was many years ago.
Walter
1967 220SL diesel
1969 280SE
2003 Beetle TDI
2005 Honda Element
DaveB
Re: big mistake....
« Reply #8 on: April 15, 2025, 02:08:32 »
I wouldn’t think it’s necessarily pistons hitting valves Figoulu. I believe the engine would likely still turn one way or the other in that case. Could the starter have got jammed somehow? Maybe take it off and have  look. If you didn’t hear anything disastrous hopefully the engine internals are ok.
DaveB
'65 US 230sl 4-speed, DB190
Re: big mistake....
« Reply #9 on: April 15, 2025, 05:28:03 »
No need to cut the chain. Remove the chain tensioner which should take some of the tightness out of the chain.
You have a valve hitting a piston which indicates incorrect valve timing. Even one tooth advanced will make valves hit pistons. Two teeth advanced and the engine will lock up solid.
No need to remove the head if you can retime your camshaft.
Figoulu
Re: big mistake....
« Reply #10 on: April 15, 2025, 05:40:51 »
Thanks for your advice.
I will do it asap
For the Time being I need to stay away from that car…
1965 230 SL
Re: big mistake....
« Reply #11 on: April 15, 2025, 07:21:33 »
Check again your valve clearances. If they have increased since you set them then that is an indicator of bent valves due to incorrect camshaft timing.
If they are bent then you'll need to remove the cylinder head and renew the bent valves.
Figoulu
Re: big mistake....
« Reply #12 on: April 15, 2025, 08:47:09 »
Thanks a lot for the advise !
My pro went back to me and ask me to send it back to him
1965 230 SL
Re: big mistake....
« Reply #13 on: April 15, 2025, 12:53:15 »
We are of course very interested in what the diagnosis is, please keep us informed.
Figoulu
Re: big mistake....
« Reply #14 on: April 16, 2025, 04:24:38 »
Thanks to all for your messages including pm
At the end of the day the engine will be sent back to the pro.
When removing it from the car I will try to investigate something by just removing the rocker arm cover just to see if something obvious appears
I will post the end of the story when I know more.
For those who know the answer, do we expect the engine block/ piston / rods to be damaged or only head and valves?
1965 230 SL
DaveB
Re: big mistake....
« Reply #15 on: April 16, 2025, 08:51:46 »
That seems the best thing to do, especially if you had not altered anything after receiving the engine from them. Good luck.
DaveB
RAY
  • United Kingdom, England, Bromley
Re: big mistake....
« Reply #16 on: April 16, 2025, 17:25:12 »
Regarding the machine shop removing a lot of material may not necessarily the case. It may just be that the head had already been skimmed once or twice before ?
Re: big mistake....
« Reply #17 on: April 17, 2025, 04:44:35 »
Remove all spark plugs. Remove all the rocker arms that can be removed with the head still on the car. Next increase the clearances of the valves on the remaining rocker arms on the car until they can be removed or the engine can be turned again. Proceed until all rocker arms are removed. Next turn the engine and check the valve timing marks. Correct if needed. Next, install each rocker arm one at a time and set the valve clearance to specs.
Continue until finished, one at a time until finished or until problem occurs.
Figoulu
Re: big mistake....
« Reply #18 on: April 17, 2025, 07:50:54 »
Thanks again
In the best and the worst case, what kind of damage could I expect ?
Do you think the piston / crankshaft  could have been damaged or only head / valve ?
Once again the engine just try to start for one second
Secondly, how can I determine the new specs for the valve clearance ??
1965 230 SL
twistedtree
  • USA, VT
Re: big mistake....
« Reply #19 on: April 17, 2025, 17:00:03 »
This ^^.  It seems most likely that whoever reassembled the engine got the cam/valve timing wrong.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
Re: big mistake....
« Reply #20 on: April 17, 2025, 20:59:19 »
While that makes sense, anyone rebuilding an engine, or even just replacing a timing chain (or timing belt), would verify timing by turning the engine over at least two complete revolutions to confirm no interference. Certainly any professional rebuilder/mechanic should!
Figoulu
Re: big mistake....
« Reply #21 on: April 18, 2025, 09:31:02 »
It's not clear for me if the issue comes from a lack of control and the bad timing tuning because as far as I remember I have checked previously the alignement of the various indexes to be at TDC. And when I made the valve clearance tour, it's almost sure that previously the engine was freely truning.
this is why I guess the corrections I made to tune as the original spec made the mess, or alternatively as it has been also suggested, something like a chain link or whatever loosen screw, has blocked the rotation. this week end I will investigate because I don't hide that removing the engine doesn't please me so much... because I will need to fight again to put it back in the car... So much fun to come...
1965 230 SL
Re: big mistake....
« Reply #22 on: April 18, 2025, 12:56:09 »
It is true that in order to check and set the valve clearances, you would have had to rotate the engine at least to some degree (pun intended). I am thinking a bolt or other object is obstructing the rotation. Wish I was there to help diagnose, good luck with the investigation ... Do try out the various suggestions by Joe A and others.
Re: big mistake....
« Reply #23 on: April 18, 2025, 14:25:50 »
Since the valves are directly perpendicular to the flat top pistons on these engines, you most likely do not have major bottom end damage. The valves do not usually get bent or damaged when they are perpendicular to the pistons. In severe circumstances the valves are jammed upward breaking the camshaft or the cam support. Visual check the cam supports and camshaft closely. Next follow the steps in my previous post. On other engines where the valves enter the combustion chamber at an angle, (not perpendicular to the pistons), a collision between the valves and pistons almost always results in bent valves!
« Last Edit: April 18, 2025, 14:34:12 by ja17 »
Re: big mistake....
« Reply #24 on: April 18, 2025, 14:42:22 »
There is always the chance that you had something that was loose and fell into the timing chain and jammed the engine. Examine deep into the chain gallery where the timing chain meets the crankshaft sprocket. In some other case a loose part in the intake manifold can be sucked into the combustion chamber, during start-up, locking up the engine.
