Author Topic: Inertia belts in a california coupe  (Read 1261 times)
« on: April 24, 2025, 15:34:22 »
We're well used to installing intertia reels in normal 113s but we've been tasked with installing them on a California Coupe and this is presenting something of a challenge.
The B post has the threaded insert at shoulder height but because the B post is different on a coupe the mounting point is at 90 degrees to the thrust line of the car rather than the usual 45. This in itself might not be too much of a drama but where we would normally weld in an anchor plate at the bottom of the B post so that the reel is hidden under the bench it is not possible because the inertia reel sits too high so as to prevent the rear bench seat from fitting into place.
Has anyone come across this before or better still got any photos of such an installation?
MikeSimon
  • USA, OH, North Royalton
Re: Inertia belts in a california coupe
« Reply #1 on: April 25, 2025, 21:24:12 »
Let me go a step back and ask about the regular W113: Do you install the reel under the rear cover behind the seats? Has anyone ever done the factory recommended installation inside the B-Pillar?
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
GM
  • USA, CA, San Pedro
« Reply #2 on: April 26, 2025, 16:19:11 »
Here are photos and supplies that I used, thanks to the guidance of fellow member, Steve Freifeld
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
GM
« Reply #3 on: April 26, 2025, 16:21:33 »
And here's the parts list I used
Gary
1971 280SL - Sold
Black MB Tex
« Reply #4 on: April 27, 2025, 09:42:48 »
Thanks GM but that looks like a normal convertible installation to me, not California coupe.
Have you got any pictures of the finished installation?
GM
« Reply #5 on: April 27, 2025, 16:44:58 »
I got distracted by
Quote
The belt from the reel slides between the wood shelf and the B pillar
Hope it helps.
Gary
Gary
1971 280SL - Sold
Black MB Tex
TJMart
  • USA, NC, Matthews
« Reply #6 on: April 27, 2025, 17:11:59 »
Stick,
I installed mine on my normal convertible installation per the Mercedes Install recommendation. I think you are saying that the California coupe's bench is lower so the reel will not fit hidden underneath it.
If that is correct then IMHO the only alternative would be to install the reel behind the seat. The only down side to that is the seats would not go as far back. The seat adjustment would be limited. As I recall there have been posts regarding behind the seat install.
« Last Edit: April 27, 2025, 17:16:25 by TJMart »
Tony
1970 280SL, 4 Speed
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #7 on: April 28, 2025, 14:51:15 »
Mine is installed behind the seats, you are only giving up 1” of seat adjustment. Unless you have really long legs this position for the reel is not a problem.
Robert Hyatt
Williamsburg, VA.
« Reply #8 on: April 28, 2025, 15:52:38 »
Indeed, under the bench is where I normally install them but that doesn't work for a California coupe.
The customer is 6'4" and doesn't want to lose the leg room.
MikeSimon
« Reply #9 on: April 28, 2025, 16:33:40 »
The original Mercedes Benz Service Bulletin describes a method to install the reel inside the B-Pillar. It is quite involved, but I guess doable for a pro with a shop
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
Philippe VIARD
  • France, Picardie, Aumont en Halatte
« Reply #10 on: April 28, 2025, 19:38:32 »
La note MB service information de Mai 1989 ref n° MBNA 91/15 donne des informations pour l'installation de ceintures rétractables. Il n'y a pas d'information pour le modèle California
« Reply #11 on: April 29, 2025, 13:01:24 »
Which translates to:
The MB service information note of May 1989 ref n° MBNA 91/15 gives information for the installation of retractable seat belts. There is no information for the California model
MikeSimon
« Reply #12 on: May 01, 2025, 16:43:29 »
This will also apply to California Coupé. It's the only MB Service Bulletin issue regarding retractable seat belts I am aware of.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #13 on: May 01, 2025, 17:39:55 »
Except it doesn't apply. The conventional installation method doesn't work on the california coupe.
MikeSimon
« Reply #14 on: May 01, 2025, 19:12:47 »
Seems like we are talking past each other. What is the conventional method? If it is under the rear covers it is not what is described in the MB Service Bulletin.
here is a scan of 2 pages from the original MB SB, which is 4 pages total. Second page shows the location of the reel behind the B-pillar cover in the right top picture. Sorry, my original is not the best quality.
« Last Edit: May 01, 2025, 19:21:54 by MikeSimon »
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
