Author Topic: just want to double check something.  (Read 272 times)
Paul99
  • United Kingdom, England, Hampshire UK
  • 230 SL White. 1966.
« on: April 27, 2025, 08:51:11 »
So (see photo) the points should be closed (ie touching) when cold and ignition off - correct?  then should open when cranking etc.
Mine had a large gap when cold.  I have adjusted so they JUST touch when cold..   Is that correct? couldn't find the link on the technical manual.
Many thanks
BobH
Re: just want to double check something.
« Reply #1 on: April 27, 2025, 09:25:58 »
Hello Paul, that's correct, contacts are normally closed, open when cranking after the coil has heated up after one second
Test procedures are on here:
https://www.sl113.org/wiki/Engine/TimeSwitch
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Paul99
« Reply #2 on: April 27, 2025, 14:48:14 »
Great. Many thanks.
