Author Topic: Block linkage repair  (Read 131 times)
djhando
  • Australia, South Australia, Adelaide
« on: Today at 06:19:55 »
Hi All
Anyone have access to the block linkage to give me some dimensions please? Mine has been modified at some stage and needs to be repaired. Distance between balls and distance from pivot to balls.
One photo is off my vehicle, other is borrowed from this site.
David
Re: Block linkage repair
« Reply #1 on: Today at 08:47:12 »
Just for your consideration: this part is available at Mercedes, A 127 070 20 22, for less than a hundred US dollars (here in Europe).
djhando
« Reply #2 on: Today at 12:10:05 »
Thanks for the suggestion.
« Reply #3 on: Today at 20:30:44 »
You may be able to find a good used one at a breaker's yard, or (your equivalent of) Ebay. They don't wear out typically I would think (not sure whether there is a plastic bushing inside the pivot point).
