Author Topic: Block linkage repair  (Read 186 times)
djhando
  • Australia, South Australia, Adelaide
« on: April 29, 2025, 06:19:55 »
Hi All
Anyone have access to the block linkage to give me some dimensions please? Mine has been modified at some stage and needs to be repaired. Distance between balls and distance from pivot to balls.
One photo is off my vehicle, other is borrowed from this site.
David
Re: Block linkage repair
« Reply #1 on: April 29, 2025, 08:47:12 »
Just for your consideration: this part is available at Mercedes, A 127 070 20 22, for less than a hundred US dollars (here in Europe).
djhando
« Reply #2 on: April 29, 2025, 12:10:05 »
Thanks for the suggestion.
« Reply #3 on: April 29, 2025, 20:30:44 »
You may be able to find a good used one at a breaker's yard, or (your equivalent of) Ebay. They don't wear out typically I would think (not sure whether there is a plastic bushing inside the pivot point).
« Reply #4 on: Today at 01:08:14 »
That linkage is for an early header pipe 230SL. Not so easy to find.
1988 560SEC
djhando
« Reply #5 on: Today at 04:32:26 »
I have cut and welded existing to suit the adjusted linkages.
David
