with our official
Pagoda SL Group logo
from our official partner.
General Discussion
got a loud whistling noise from the air valve
Topic: got a loud whistling noise from the air valve (Read 2557 times)
erickmarciano
Associate Member
Gold
Canada, Quebec, montreal
August 14, 2005, 22:07:03 »
just replaced the chain so I has to reajust the timming and idle and fuel mixture . the car runs great but I have a loud whistling noise from the air valve , the idle is great so is the co% . how can I minimize this noise?
thnaks
Erick
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Full Member
Platinum
Australia, Queensland, Brisbane
Re: got a loud whistling noise from the air valve
August 15, 2005, 04:10:17 »
Is the noise when the engine is hot or when it is cold (warming up)?
erickmarciano
Associate Member
Gold
Reply #2 on:
August 15, 2005, 07:35:43 »
when hot . it is the air adjusting screw near the ventury.
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
enochbell
Reply #3 on:
August 15, 2005, 09:54:08 »
Are you sure you do not have an air leak somewhere else? Sounds like the idle air inlet is trying too hard to pull air from in front of the venturi. And if everything else (idle speed, timing, emissions) checks out OK, your engine may be getting the air it needs from somewhere else. Check to be certain there is no leak past the butterfly at idle, also check
http://www.mercedesshop.com/shopforum/showthread.php3?t=125019
For diagnostics on air leak issues
Otherwise teach it to whistle something you like, and just enjoy it...
Greg
General Discussion
