Author Topic: Need help ! Pump housing and PAS bolt !  (Read 4449 times)
« on: August 15, 2005, 10:18:41 »
Does anyone have a good used water pump housing ? I have some damaged threads where the little bypass pip bolts on with the hollow banjo bolt. New ones seem very expensive !
I tried a repair with some liquid metal but the threads are too bad and I’m not happy with it. Anyone have something from a parts car maybe ?
Also the power steering pump lower pulley bolt……………..I’m missing one and none of the catalogues or on-line shops show what I need !
Re: Need help ! Pump housing and PAS bolt !
« Reply #1 on: August 15, 2005, 10:41:02 »
Hello Ben,
Another option is to install steel thread inserts. All sizes and metric are avaiable. You can by a kit with the correct drill bit, inserts and tap.
Mike Webster
« Reply #2 on: August 15, 2005, 13:12:19 »
Ben,
Go to www.helicoil.com Good luck!!
Mike
« Reply #3 on: August 16, 2005, 03:18:44 »
Thanks for your response guys and for that link !
I had though of helicoils but cant seem to find a local supplier !
The hunt is on!
« Reply #4 on: September 02, 2005, 09:15:14 »
Okay just thought I'd wrap this one up !
I managed to get the helicoil fitted, then a bolt sheared in the thermostat housing. I had to drill and retap that, which was succesful, the thermostat was incorrect and opening too early so I fitted a new one.
It's back together again and I drove it for the first time in 5 weeks !
It felt great and ran better than ever. I think the coolant being to slow meant that sometimes the WRD opened up again !
Anyway I also replaced the sleeves in the clutch master cylinder and fitted the overhauled power steering pump and resvoir that I have been looking at for over a year. It may be a while before I finish that job but I wanted to ensure I had all the relevant fittings !
Still need a photo of a stripped clutch slave cylinder, or in fact i would buy a used one if anyone had one, then just fit new seals to it !!
Good to be back driving again............and the good news is I got the green light to build my new garage for next year !!   [:p]
« Reply #5 on: September 03, 2005, 04:06:45 »
Hey Ben,
What temp thermostat did you end up installing?
« Reply #6 on: September 05, 2005, 02:33:00 »
Hi Bob, I used the 83deg one !
The car runs great now and I have nice hot air which I never had before.........great for this time of year as its getting chilly here but still sunny enough for top down !!
« Reply #7 on: September 05, 2005, 05:52:50 »
Ben,
All the earlier discussions on the Yahoo site recommended 79C thermostats but when I asked MB their recommended temp range was 87C. I think it is to do with the sub tropical climate here.
I decided to go with the 79C unit. The original thermo in the car was a 79C, so I made the right choice.
« Reply #8 on: September 05, 2005, 08:36:57 »
Oh maybe it IS 87 deg !!
Its definitely eighty something, I dont recall now, maybe the paperwork will tell me for definite!
Thing is here in Ireland it never gets near the outside temperature that you guys get to so I felt the coolant never gets warm enough !
It always read cold before, just under the 180 square block on the gauge !
« Reply #9 on: September 12, 2005, 21:56:50 »
I think I have an 83 in my car.  I recall three choices and picking the middle of the road.
