Author Topic: how do to remove cover for rear axel mount  (Read 2456 times)
erickmarciano
  • Canada, Quebec, montreal
« on: August 15, 2005, 22:30:03 »
does anyone know how to remove the cover for the rear axel mount?
thanks
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
  • USA, VA, Alexandria
Re: how do to remove cover for rear axel mount
« Reply #1 on: August 15, 2005, 23:04:23 »
There are 2 plastic pins or fasteners that hold it in place.  Gently pry the cover up and part of the fastener will fall into the support rail that the axle mount sits on.  To my knowledge, you can't retrieve the pins from the cavity, so you will need to get new pins/fasteners.  Not sure if these fasteners are readily available.
« Reply #2 on: August 15, 2005, 23:50:04 »
Interesting... mine is held down by metal screws. Perhaps the previous owner didn't bother using these plastic fasteners...?
WAQAS in Austin, Texas
« Reply #3 on: August 16, 2005, 20:59:15 »
If we're talking about the plastic cap in the trunk, then mine is held down by two phillips-head screws.
