Author Topic: Light Weight Disk Wheels  (Read 4753 times)
JimVillers
  • USA, VA, Virginia Beach
« on: August 28, 2005, 16:05:41 »
At Blacklick, I showed and discussed aluminum disk wheels that could replace wheels on cars with hubcaps.  I found some more information on them. The 6J 14 H2 wheel was used on 1977-81 280E and 300D automobiles.   The part number is 123 400 15 02.
Jim Villers
Jim Villers
Re: Light Weight Disk Wheels
« Reply #1 on: August 28, 2005, 21:57:03 »
I have these exact same wheels on my car.  There's quite a difference in weight compared to the original steel wheels.
CarlG
« Reply #2 on: August 29, 2005, 16:13:27 »
Are these wheels only for the later cars with one piece hupcaps?
1967 230sl (stick)
« Reply #3 on: August 29, 2005, 16:52:47 »
Carl,
Yes, b/c they do not have the 3 little dimples to hold the small hub caps.
And the ones I've seen (that are standard on the 123s) are a lighter gage steel, not ali.
JimVillers
« Reply #4 on: August 29, 2005, 17:53:06 »
Naj .... I believe that these were used only on the USA delivered automobiles.  They are "Light Alloy Rims" (aluminum) (page 40.5 102/8 of the 123 book).  They will not hold the small hubcaps without adding the clips from the 190SL wheels (a number of 190SL guys have done that:
http://www.190slgroup.com/tech/images/rob_car2.jpg
Jim Villers
« Last Edit: August 29, 2005, 17:56:35 by JimVillers »
Jim Villers
« Reply #5 on: August 29, 2005, 18:38:13 »
Naj, I can confirm that these are in fact alloy.  As mentioned before I have the same exact wheels on my car.  In fact I had posted this information in a prior post (14 july 2004)in the photo gallery entitled "Photos from Hauser" courtesy of Cees Klumper.
« Reply #6 on: August 30, 2005, 17:37:31 »
Jim:
I called Caliber motors so I can run the part number for the light wheels 123 400 15 02 for a price on a 208-E from 1977 to 81. I am told that part number does not exsist in the USA books is this an option for European cars only? The only two rims availible for the 280-E are steel or alloy mag. Can you comment on this and were I can fine these wheels?
« Last Edit: August 30, 2005, 17:38:20 by Bob G »
« Reply #7 on: August 30, 2005, 17:56:23 »
Bob, I seriously doubt you'll find these from a dealer.  Your best chances are a MB dismantler.  My wheels came from a 1980 300D US version.  I'm not sure if these wheels were offered in Europe.
Vince Canepa
« Reply #8 on: September 01, 2005, 05:49:05 »
These wheels are shown in the wheel section of the W123 chassis manual.  My 240D had the 5.5" aluminum versions.  However, they are no longer supplied by M-B.  Ordering the part number for an alloy wheel will get you a steel wheel (several tries to figure this out).  When I needed a replacement, I finally obtained a used one from Potomac German Auto.  The 5.5" ones were fairly easy to get then (1999 I think).  The 6" versions are less plentiful.  They are distinguished from the steel wheels by the silver band on the "hump" outside the bolt circle.  The 5.5" versions have 4 silver "stripes" rather than a continuous band.
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
Arjun
« Reply #9 on: March 12, 2006, 20:07:06 »
Would the 5 1/2 inch of the 240D fit into our sl's
1967 250SL 5-Speed
  • USA, VA, Alexandria
« Reply #10 on: March 12, 2006, 20:41:47 »
Arjun,
Yes, the 5 1/2 inch rims work on our cars.  I switched back to these last fall and they are currently on my gold car.
Arjun
« Reply #11 on: March 12, 2006, 20:54:46 »
Got my hands on the following.
The wheels are stamped 1234991302 Lemme and 5 1/2J x 14 H2.
These have come from a 82 240D.
Download Attachment: 1f_1.jpg
37.73 KB
1967 250SL 5-Speed
« Last Edit: March 26, 2006, 04:09:44 by Arjun »
