Author Topic: End link bushing for sway bar  (Read 2963 times)
RBurg
« on: September 07, 2005, 07:29:41 »
HELP!  HELP!
Does anyone know where I can purchase the bushing for the sway bar end link.  There is a set of 8. MB only sells the complete set as a totale rebuild kit for over #$100.00
Bud Benz just sent the parts and they are totale wrong. They sent front axel rings and call them sway
bar end links.
Ron
71 280SL Tobacco "O GIGI"
97 E420 Silver Mist
enochbell
Re: End link bushing for sway bar
« Reply #1 on: September 07, 2005, 08:05:34 »
Ron,
You must have gotten the bushing I sent back to Bud's, they made the same mistake with me.  They are usually great with service and accuracy, I would suggest that when you work with them you specifically ask for Dave, he is very knowledgeable.  As for a partial kit, I was not able to find it, the "rebuild" comes with the two front bushings and the doughnuts for the bar ends and yes, it runs a little over $100.
Good luck,
g
« Reply #2 on: September 07, 2005, 21:09:10 »
Hello Ron,
If you don't mind non orig, Autozone has poly urethane ones for about $10.00 (both sides) with hardware.
« Last Edit: September 07, 2005, 21:09:56 by ja17 »
RBurg
« Reply #3 on: September 09, 2005, 07:19:56 »
Joe:
Thanks for the tip on bushings - how will they work if it is not as large as the orginial?  will it move around  or stay centered?
Ron
97 E420 Silver Mist
