Author Topic: Distributor vacuum advance pipe  (Read 2595 times)
saygold
« on: September 09, 2005, 10:54:32 »
I am finally getting ready to start my car after rebuilding my cylinder head.  The problem with waiting so long is that I don't remember where everything goes.  I installed the distributor cap and plugs and was trying to sort out the distributor vacuum advance piping system. I found it at the distributor end, but I could not find a location that would accept the vacuum pipe.  I don't think it is supposed to just hang out in space.
I would appreciate information about where the vacuum pipe intake point is.
Thanks in advance for your help.
Ken
66 230SL (4-speed, euro)
DavidAPease
  • USA, CA, Chico
Re: Distributor vacuum advance pipe
« Reply #1 on: September 09, 2005, 11:05:03 »
Ken,
There was some discussion of vacuum take-off in this thread
http://www.sl113.com/forums/index.php?topic=2347
Look for Naj's photos about half way down, and also my response a few posts later (since I also have a '66, though it seems it may not be completely stock in the distributor area).  Once you figure this out, perhaps you'd let us know what you find; I'll be curious to see if it's the same as mine (# 015461).
-David Pease
'66 French 230SL
-David Pease
saygold
« Reply #2 on: September 09, 2005, 12:25:45 »
David,
Thanks a lot!  It is amazing how easy it is to find information through this website.
My car's vacuum pick-up point is the same location as yours is using.
I have S/N 10-016445 and it has the Bosch 0231 116 051 JFUR 6 distributor.
Ken Deter
'66 230SL (4-speed euro)
