Originally posted by Ed Cave
I use one of these form-fit covers for both my Pagoda and 911. They are easy to take on and off, light and easy to store, fit nicely to the body of the car but can be used indoors only. A very nice product in my opinion.
http://www.webcovers.com/CarCovers/FormFit/
1973 911S
2004 A4 3.0
2006 GS430
Hello Ed. A short while ago I started to order one the CoverCraft "Form-Fit" covers for my Pagoda, but confusion arose during the process so I decided to hold and seek input before proceeding.
Since you've already gone through this, and are satisfied with the product and its fit, I have a question about cover size.
Background: As I was going thru the on-line selection process (e.g., 1971...Mercedes-Benz...280SL...convertible/coupe/size G3...etc), and even though they clearly state that the cover stretches, I began to wonder if the recommended cover (G3) is sized with a W113 specifically in mind. In order to test this out I then went through the cover selection process again, but this time for a 280SE. What I learned was that the online selector choses the same size ("G3") for both the 280SL and a 4-door 280SE. So then, perhaps to confuse myself even further, I decided to go through the selection process once more; except this time I did it for a 1970 Porsche 911. (I also owned a 911S, but that was many moons ago). For the 911 the online selector came up with a size "G2", which I assume to be smaller than the G3.
Before I place an order I was wondering if you could comment on the G3 size for the 280SL. It's probably fine, but as you can tell, I'm concerned that it might be a bit large, especially since the G3 is also the recommended size for a 4-door 280SE ... and whereas a G2 size is automatically selected for a 911.
Sorry for all this confusing input, but your input would be appreciated, assuming my ramblings here make any sense to you.
Thanks.
Tom in Boise
