Author Topic: prime fuel system?  (Read 3278 times)
merrill
prime fuel system?
« on: September 18, 2005, 16:46:53 »
recently I changed my fuel filter & did not replace the fuel in the filter housing.
Do I need to do anything to prime the fuel system?
should I just let the fuel pump run a little longer before cranking the motor?
Thanks in advance.
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
Re: prime fuel system?
« Reply #1 on: September 18, 2005, 20:36:51 »
You can purge the air by losening the connector on the top of the filter housing and then turning the key to get the pump running.  The air will hiss out quickly and when you start to get a flow of fuel out the threads, re-tighten the connector.
Even if you do nothing, the air that gets into the system should not be a big problem.  The engine will probably crank longer before starting or run and stumble, miss or stall at first, but should be fine after it runs a bit.
'68 280SL 4-spd Coupe
« Reply #2 on: September 18, 2005, 21:56:56 »
Hello Matt,
The engine will self prime. It may take little extra cranking. Remember the fuel continually circulates in a loop and goes back to the fuel tank. Just turn the ignition key and let the electric fuel pump run for about 30 seconds this will fill the fuel canister and purge the line. Push the accelerator to the floor while cranking for this start. Some air may  get to the injector lines but will soon be gone.
Chad
« Reply #3 on: September 18, 2005, 23:30:47 »
this may sound silly, but i routinely let the pump run for some time (20-30secs) prior to cold starts. somewhere i imagined reading its to generate good pressure in the pipes.  the car starts fine.  does this make sense?
-CD-
1967 230SL, 113.042 10
1983 300TDT, 123.193
« Reply #4 on: September 25, 2005, 20:36:47 »
Chad,
That shouldn't be necessary.  Try 10 seconds on your next cold start, then 5 on the next one, and so on.  You will eventually find what's necessary for your particular car.
Chad
« Reply #5 on: September 25, 2005, 21:14:06 »
Sounds good will do.
-CD-
