Author Topic: shifter dropped in  (Read 23000 times)
Re: shifter dropped in
« Reply #25 on: December 18, 2008, 20:54:11 »
When I checked Naj's shopping list prior to ordering, I found what I think is a typo.  The bushings for the shifter ball should be 111 267 (not 268) 00 86, according to the EPC.  The Item Number is 258.
Thanks for pointing out the error, Chuck.
Like the guy said ' My fingers are not my own when I'm typing'
I have corrected it on the wiki.
I guess you found the post in one of the discussions?
ctaylor738
  • USA, VA, Falls Church
« Reply #26 on: December 19, 2008, 13:52:08 »
Actually, it came up in a Search.
BTW, I pulled the shifter out last night and the ball's bushings came out in largely unrecognizable pieces.  All of the pieces were available from the dealer overnight except for the wavy washer, which is coming from Germany.  Joe's method for removing the shifter knob worked, but it took a fair amount of bashing to get it off.
Thanks to all for a very helpful thread!
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
« Reply #27 on: December 19, 2008, 14:44:41 »
OK, found it and corrected.
Thanks again.
ctaylor738
« Reply #28 on: December 22, 2008, 14:33:58 »
Just to close the loop, Chad stated earlier that he couldn't locate the 7mm-1 "nyloc" nuts used in a couple of places.  I needed one as well and found an acceptable lock nut at Home Despot.  They had an assortment of these nuts from 4mm to 8mm.
Chuck Taylor
1963 230SL #00133
Falls Church VA
