Author Topic: differential ratios on 280sl  (Read 3741 times)
« on: September 19, 2005, 21:04:45 »
Does anyone know about a differential ratio change on the 280sl?
I was asked if my car has a lower differential ratio.  It is a 1971 early production dated 9/70.  I was stumped.  Was a change made to the 4 speed manual that would effect lower rpm's at 65 mph in 4th gear at some point during production?
This is news to me.  And I thought I knew a heck of a lot about these cars.  Frank Mallory's list of changes does not show anything, and the service manual doesn't appear to list anything.
Any help out there??
Don
1971 280sl 4 speed manual
Re: differential ratios on 280sl
« Reply #1 on: September 20, 2005, 02:09:04 »
You're okay, Don. Your car should have the 3.92 rear. In January of 1969, the US-spec cars went from a 4.08 to the 3.92. They started at Serial #011132.
« Reply #2 on: September 20, 2005, 04:55:47 »
Hello Don,
The car could also be ordered with a different ratio. You can find the ratio stamped on the differential casting driver's side lower on the edge of the casting web.
Early 230SLs had the ratio stamped on the rear lower  of the differential in a semi-circular machined surface.
« Reply #3 on: September 20, 2005, 08:26:52 »
Adding to what Douglas wrote, the non-US 280 SLs started out with a 3.92 ratio (US ratio was 4.08), then at chassis no. 011132 the non-US cars went to 3.69 while the US cars went to 3.92.
With the 3.92 my car shows 70 mph (110 kph) at 4000 rpm.
« Reply #4 on: September 20, 2005, 10:08:11 »
Thanks for the quick responses!  This was a new one on me.  Ya learn something everyday, eh?  Particularly from such a knowledgable group as this one.
Best regards,
Don
