with our official
Pagoda SL Group logo
from our official partner.
General Discussion
OIL fill cap leaks after putting in Mobil 1
Topic: OIL fill cap leaks after putting in Mobil 1 (Read 2769 times)
September 21, 2005, 04:29:30 »
looking at the cap visually I can see no problems with the fitment or the gasket but after changing to Mobil 1 it leaks OIL down the sides of the cam cover not a lot but enough to create a smell. Is this slimey stuff somehow working its way under the gasket, I am at a loss...anybody else havingthis problem...how did you solve it...thanx
tuultyme
Re: OIL fill cap leaks after putting in Mobil 1
September 21, 2005, 05:07:02 »
You may have to buy a new gasket; it may look OK but if it is older it may be starting to get brittle or slightly deformed do to continual use.
Reply #2 on:
September 21, 2005, 06:44:18 »
Agree with Bruce. I use Mobile 1 and do not have any leaks.
Full Member
Platinum
USA, OH, Blacklick
Reply #3 on:
September 21, 2005, 09:17:46 »
Do you still have the originasl metal cap? The black plastic replacement caps tend to leak. As sugested I would try replacing the gasket first or the whole cap if you have the plastic one.
General Discussion
