Originally posted by A Dalton
BS
Is there a part# on the sender.
All the 108 senders I see are the same # as 113 cyl type.
Even the 4.5
Arthur,
I had another look, there were no MB numbers but this is what I found.
OLD cylindrical SENDER that was originally in CAR
TOP MARKINGS
VDO nur f Benzin
11 66 <<is this the make date?
21/169
LENGTH 150mm
RESISTANCE WITH FULL TANK 59.4 Ohms
RESISTANCE WITH EMPTY TANK 118.4 Ohms
NEW cylindrical SENDER FROM 108
TOP MARKINGS
VDO
xxx 73
21/293
673
LENGTH 190mm approximately
RESISTANCE WITH FULL TANK 4.5 Ohms
RESISTANCE WITH EMPTY TANK 65.5 Ohms
Neither of these senders give me a correct reading that is why I asked about the 'EARLY' 250sl and the float type sender.
There was a discussion about this some time ago and it came out that the gauges were different for the different types of sender.
