Author Topic: lowering car without spring  (Read 2789 times)
Khurram Darugar
« on: October 10, 2005, 17:14:37 »
Is it possible to lower your car onto the ground missing one rear spring, without having the wheel completely collapse in the wheel well?
I am waiting on some parts before i can put in the new springs but need to get the car turned around in my garage so i can get access to the other side in the mean time (Narrow garage).
If anyone knows maybe i could rule this option in/out.
Kay
« Last Edit: October 10, 2005, 17:16:09 by Khurram Darugar »
Re: lowering car without spring
« Reply #1 on: October 10, 2005, 20:58:36 »
Hello Kay,
Some wood blocking, where the spring once rested should work enough to move the car. Ask me how I know? I own an old air suspension 6.3 Mercedes!
Khurram Darugar
« Reply #2 on: October 11, 2005, 06:14:39 »
Thanks Joe,
           I may try that , however the suspension pivot on which the spring rests is not connected to the base plate (which has been removed) on the floor board.
I will lower the car slowly and see what happens[:p]
Kay
« Reply #3 on: October 11, 2005, 09:23:53 »
You do not want to be trying to turn that car aroud with the control arm dis-mounted . You could rip that hanger right out of the trunk. What JA is saying is that you can fill the spacing of the removed spring to keep the car up , but you certainly want the arm mounted....
Khurram Darugar
« Reply #4 on: October 11, 2005, 13:41:21 »
Ok will Do  ;)
