Author Topic: Kickdown switch  (Read 3571 times)
Kickdown switch
« on: October 11, 2005, 08:27:10 »
Last night I pressed down on the kickdown switch while driving at highway speeds and the car gladly downshifted, much to my surprise. Does the kickdown switch always engage a lower gear regardless of your speed? I just replaced mine, so I'm wondering what its "normal" state should be.
Re: Kickdown switch
« Reply #1 on: October 11, 2005, 11:32:29 »
I've had mine kick down at speeds under 30, but recently I decided to run a "yellow/orange" light...  was going about 50ish...  surprisingly, the car kicked down and it soared to 70ish very quickly!  So, my kickdown seems to work whenever I press the pedal to the metal...
Memphis, TN.
1997 E320
Re: Kickdown switch
« Reply #2 on: October 11, 2005, 11:51:42 »
Hey Douglas,
Yours seems normal. My kickdown switch is way way down there, so I rarely ever get to it in normal driving. In fact, thought it was inop for years since I never floored the pedal. But I investigated and it works. In my case, upon flooring the pedal, it kicks down fine but does so at very high revs. Kind of scares me as I am not the high RPM type.
Re: Kickdown switch
« Reply #3 on: October 11, 2005, 15:51:43 »
I don't think it will work if you are already in the 5,000+ RPM range or thereabouts. I believe I have tried.
68_white
  • USA, TX, Houston
Re: Kickdown switch
« Reply #4 on: October 31, 2005, 20:25:46 »
Your auto transmission will down shift when the kickdown switch is activated as long as the vehicle speed is not over 60 mph.
HARRY
68_WHITE
HARRY
1970 280SL RED
2002 E430 SILVER
1996 911 BLUE
