<<The Inj Pump Solenoid (under a HOT start condition) would only be activated for 1 second instead of the full cranking time...probably not a problem. It would be controlled by the TTS under Cold Start conditions.
Which is fine .. the 230 had the 1 sec reay and the 250 did not .. they later found that the rack sol was not needed , but they modified the system again and went back to the 1 sec relay system of the 230.. So, you lose nothing by having the rack sol working off the TTS..
There were 3 changes and the best change was when we added an override in the cabin...
In all actuality , the most important part of start comes down to the CSV,,,,and the 1 sec relay solved most of the later hot start problems. Turns out that the 230 system was best , but the pump itself needed a little cleaning up in the design of the cone check valves , which were changed to ball valves .. that is when the rack sol was found to no longer be needed .. I personaly prefer the early pumps , as I do not like crankcase oil in my pump.
...but if I were not a Tech, I would prob not be concerned with it.
