Author Topic: Data Card - what's 242?  (Read 4099 times)
« on: October 25, 2005, 14:37:19 »
Anyone know what 242 is on a 1970 280 SL data card? It's not indicated in the database on this site.
Thanks for any insight out there.
Re: Data Card - what's 242?
« Reply #1 on: October 25, 2005, 14:55:47 »
Doug,
At
http://www.bekkoame.ne.jp/~mtor/mbcodedsc.html
I saw a reference to 242 as "spare wheel without tire"
I will also take a look through some of the reference material I have at home tonight to see if I can confirm that.
« Reply #2 on: October 26, 2005, 04:48:25 »
Doug,
I did some further checking through some other lists and reference stuff I have at home, but could find no other reference to the 242 code other than the link already shown.
« Reply #3 on: October 26, 2005, 06:10:47 »
Thanks, Jonny. I think the codes changed a bit over the years, so I'm pretty sure it's not "spare wheel without tire" for a Pagoda SL. I'll check with Gernold.
Klaus
« Reply #4 on: October 26, 2005, 09:21:03 »
Doug,
are you sure you are not looking at the box "Ausstattung"?
Klaus
1969 280 SL
« Reply #5 on: October 26, 2005, 10:19:49 »
Doug,
I shall be curious to learn what you find out, and where all these lists exist. I do understand what you mean about the codes changing over the years.
norton
« Reply #6 on: October 26, 2005, 11:17:24 »
  As you go into the 70's, 80's and 90's the code numbers are for different things. In the 90's code 242 is for right front seat electrically adjustable with memory feature.
http://www.geocities.com/MotorCity/Speedway/5350/mbcodes.htm
Mike Halleck
Chesterfield Mi
71 280SL
68 250SL (parts car)
94 E320 Coupe
« Reply #7 on: November 17, 2005, 20:59:41 »
Doug,
I still don't see 242 in our database.  Did you ever find out what it is?
« Reply #8 on: November 17, 2005, 21:18:50 »
Rodd,
I'm pretty sure code 242 is "Driver fitted with spare tire."  :)
(No, I never did find out what that code was.)
Mahopac, NY
« Reply #9 on: November 18, 2005, 18:54:21 »
Doug,
I like your take on the code. I guess the spare tire is something that comes with an aging car?? Or is that the aging owner??
