Author Topic: shift boot replacement  (Read 3230 times)
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« on: October 26, 2005, 20:59:39 »
Any tips for replacing a new shift boot on a manual transmission? Do I need to pull the carpet up? It's not clued down. Or can I just replace it from the top. Do I need clue or anything or does it just snap in?
thanks
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Re: shift boot replacement
« Reply #1 on: October 26, 2005, 21:39:24 »
It's not hard to do. I replaced mine when replacing the shift lever and interior bushings. I didn't pull up the carpet but the boot was glued to the carpet. Just pull it up and glue the new one in. Others may be different.
Brian
66 Natural Red 230sl
ted280sl
  • USA, NY, New Rochelle
« Reply #2 on: October 27, 2005, 08:19:30 »
Obviously the shift knob needs to be removed to slide the new shift boot on. The shift knob is only held on by friction. I have removed mine by placing a pair of pliers around the shaft beneath the knob and tapping the knob lightly with a hammer. Be prepared to catch the knob. Mine flew off the shaft.
regards,
Ted 1969 280SL w/ 4 speed and "new" boot
