Author Topic: Suspension  (Read 3440 times)
harleydan
Suspension
« on: November 11, 2005, 21:39:24 »
My 1970 280SL (European model with a manual 4 speed) runs great but the suspension needs improvement.  Upon accelleration the front end of the cars lifts up.  On curves the car leans too much in the wrong direction which lessens control of the automobile.  The car feels like a boat.   I want to stiffen up the suspension for a more sportier and controllable ride, but not too much as too feel all the bumps.  What do you recommend?  New shocks (Bilstein or Koni or whatever)?   New springs possibly (what kind and size)?  Or any other suggestions.
Re: Suspension
« Reply #1 on: November 11, 2005, 21:55:13 »
Start with the basics -- shocks, engine mounts, steering shock, front subframe mounts, tie rods, center drag link......
Re: Suspension
« Reply #2 on: November 11, 2005, 22:22:21 »
Good advice Doug, especially the shocks. Also check the front sway bar connecting links and rubber bushings.
blairwag
Re: Suspension
« Reply #3 on: November 11, 2005, 23:09:35 »
I agree with Doug and Joe. Bilstein or nothing on my car - they're worth the bucks and more closely resenble OEM shocks. If you have a lot of body roll, though, you're most likely looking at bushing problems. The Shocks won't really impact that too much. If the car steers straight, and doesn't tear up the tires, it'll be bushings. If the bushings all look pretty tight, poor front end alignment can also cause just instability problems. Shoot at that next.
1971 280SL US Automatic
JimVillers
  • USA, VA, Virginia Beach
Re: Suspension
« Reply #4 on: November 12, 2005, 06:59:35 »
harleydan ..... To tighten up the car, do the basics first.  My recommendation is the Koni Classic adjustable shocks.  You can adjust the damping to the feel that you prefer.  Next, replace the sway bar bushings with a harder bushing.  The outside sway bar link bushings are available at most auto parts stores, the universal sway bar bushing from Energy Suspensions for your sway bar diameter will work for the frame mounts.  This tighten the cornering feel and reduce corner lean somewhat.
Jim Villers
Jim Villers
Re: Suspension
« Reply #5 on: November 12, 2005, 14:23:48 »
My experience with koni shocks has always been that they tighten up the suspension giving  up a poor ride in place of handling. This is good if you are racing on the track but unhealthy for the drivers back and dairer when trying to enjoy a Sunday afternoon outing with his wife.
I have Koni red shocks on my 1987 Mustang, it took a year to break them in and I have not touched the adjustment for the front shock or the rear.
I wonder how Takio shocks would work? Ford approved them for the Corba Mustangs and the GT. You can also adjust the shocks much easyier then the konies and I think they would offer the same performance and a better ride.
« Last Edit: November 12, 2005, 14:24:47 by Bob G »
