Author Topic: Floor panel update/gas pedal bracket  (Read 3583 times)
« on: November 14, 2005, 12:25:21 »
Ordered a new lower fire wall panel from K&K and discovered that the section near the gas pedal is off set slightly to mate with the floor panel as it raises up maybe 1/2inch to meet the trans tunnel.  This mostly took car of the alignment issue with the fire wall and floor.  I've now completed installation of a new drivers side fire wall, floor pan, frame rail, seat mounting cross panel and the flat floor panel which goes under this section.  After POR15 painting and seam sealing I started laying down dynamat and remembered the gas pedal bracket.
I have a new question concerning mounting of the bottom gas pedal bracket.  That whole area of my car was rusted and repaired badly so I don't have a reference for where to place it.  Due to its shape I have a pretty good idea of where it goes and I was looking for confirmation dimensions from anyone in the group.  Can anyone offer location details?
Re: Floor panel update/gas pedal bracket
« Reply #1 on: November 14, 2005, 15:45:02 »
I was able to get a pic from K&K.
« Reply #2 on: November 14, 2005, 18:04:16 »
Hello Jeff,
Use the original gas pedal opening in the floor mat to locate the pedal.
« Reply #3 on: November 14, 2005, 18:18:47 »
The bottom C/L of the pedal is 14" from the left frame rail and 21 1/2" foward of the front seat rail.
 That is x/y location..measure w/carpet.
« Reply #4 on: November 15, 2005, 08:01:39 »
Thanks Arthur and Joe!
Bracket is now welded in place.  Now all I need is a new gas pedal.  My old one was rusted very badly and there is nothing left to attach to the new bracket.  Your comments are always appreciated.
« Reply #5 on: November 15, 2005, 12:20:25 »
Arthur, do you mean carpeted seat rail and frame rail? (but without the drivers carpet in?)...
« Last Edit: November 15, 2005, 12:21:04 by J. Huber »
« Reply #6 on: November 15, 2005, 13:13:44 »
  Yes .. Both rail measures reference points [ X and Y ] are with carpet.... so , if he has the rails w/o carpet, he adds that thickness to my measures , as my measures are w/carpet..
