Today I did my scheduled chassis lube and I am afraid that, for the first time since I own the car (almost four years now) I have only now located all of the grease fittings that are supposed to be serviced. Thanks to Joe Alexander's tech session in Ohio. The ones I never noticed are on the top of each of the front suspension kingpins. There are three nipples on each kingpin, one on the lower side, one on the bottom, and one on the top - which I never noticed until today, when I decided I wanted to remove the wheels (to check whether they were straight, whether the brake discs were still straight, and to check the condition of the brake pads).
These top nipples go unnoticed with the wheels on - I am not even sure you can reach them with a grease gun with the wheels in place. Fortunately, both mine took grease and there was plenty there to begin with ...
So, in all, I count 17 fittings (front: 3 on each kingpin, four more on each front wheel, then one on the front driveshaft, hidden behind the transmission support plate (this one is also almost invisible) and two more on the rear axle. My car is a 280SL, I understand 230SL's have even more grease points.
