Author Topic: SL Bosch Horns  (Read 4727 times)
SL Bosch Horns
« on: December 12, 2005, 08:52:42 »
Anyone oot there know where to buy the rebuild kits for the Bosch horns for our SL's.  I have a '69 but want to restore the horn.  I need the gaskets... two thin membrane gaskets that are used in these horns.  please advise.  best --jp in pa
j prothero
1969 280sl in Pitt, PA
dreyer635
Re: SL Bosch Horns
« Reply #1 on: December 12, 2005, 12:30:51 »
I did both horns mine om my 69 modell - I took them fully apart, cleaned and respayed them with a black paint. I did not bother with he "paper"gaskets, I think I ony used som tape etc when I put them back again. It is the metal plate making the sound, and mine worked OK afterwoards.
Re: SL Bosch Horns
« Reply #2 on: December 12, 2005, 16:47:40 »
Use a silicone sealant.
Vince Canepa
Re: SL Bosch Horns
« Reply #3 on: December 12, 2005, 17:00:59 »
The gaskets are vegetable fiber.  I bought the thinnest available from McMaster-Carr.  A bit too thick, but no real consequence.  I had to buy way more than I needed, but it was about $10 - not a big deal.
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
Re: SL Bosch Horns
« Reply #4 on: December 12, 2005, 18:58:07 »
J,
Did you use the Search tool?  Here's some info that might help you.  Maybe you can directly contact the people who posted on these threads.
http://index.php?topic=2871,restore
http://index.php?topic=3197,restore
Re: SL Bosch Horns
« Reply #5 on: December 14, 2005, 10:05:00 »
rodd, actually I wnet about this a bit butt-backwards.  I dont know why I didnt SEARCH first.  I did, however, so that right after I posted and found these threads.  In fact, Michael Salemi called me and walked me through the whole thing.  In search of the "correct" vegetable paper, I contaced Fed-Mogal and the engineer told me to forgo the paper gasket as this was the old way, and to go with "BLACK RTV".  so I went to the local auto supply house and got some made by permatex.  He said this far and away was a better solution for my purpose.  "Just follow the directions carefully on the packaging".  hey... whadaya know... another approach to fixing these things.
j prothero
Re: SL Bosch Horns
« Reply #6 on: August 03, 2006, 14:02:35 »
Hello Vince,
do you have any left that you might be willing to sell?
If not, what is the McMaster part number? I couldn't find them.
Thanks!
Vince Canepa
Re: SL Bosch Horns
« Reply #7 on: August 04, 2006, 06:42:00 »
Alfred - I have way more than I can ever use and didn't pay much for it.  Just send me an e-mail with your address and I will mail you enough to do your horns.
For info, the McMaster-Carr number is: 9453K103
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
