Author Topic: 230sl 250sl 4-speed gear ratio question  (Read 3902 times)
DaveB
« on: December 20, 2005, 21:55:22 »
Can anybody tell me if there are any differences in the gear ratios between '65 230sl  and '67 250sl 4-speed transmissions?
DaveB
« Last Edit: December 20, 2005, 23:20:14 by DaveB »
DaveB
'65 US 230sl 4-speed, DB190
Klaus
Re: 230sl 250sl 4-speed gear ratio question
« Reply #1 on: December 21, 2005, 09:11:41 »
230 SL up to production month 10/65:
I 4.42; II 2.28; III 1.53; IV 1.0; R 3.92; Diff 3.75
230 SL as of production month 11/65:
I 4.05; II 2.23; III 1.40; IV 1.0; R 3.58; Diff 3.75
250 SL as of production begin 11/66:
same as late 230 SL as of 11/65, but Diff 3.92; opt. 3.69
These are the standard ratios for German version. Some export versions may have been different, especially in rear axle ratio (diff)
Klaus
1969 280 SL
Vince Canepa
« Reply #2 on: December 21, 2005, 09:15:30 »
According to my 1969 and 1963 Technical Data books, there is a difference in ratios for the "1st Version" 230SL.  The "1st" Version has generally lower ratios in 1st, 2nd and 3r gears.  I could not find the chassis number break point for the "1st Version".  The later cars used the same rations as the 250SL.
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
« Reply #3 on: December 21, 2005, 09:49:52 »
The trans # breakpoint is <- G.011319/G.011320->
DaveB
« Reply #4 on: December 21, 2005, 21:09:26 »
Thanks Klaus, Vince and Arthur.
I have one of each transmission. Based on that gear ratio information I think I might swap out the early one for the later.
DaveB
DaveB
